Home » Archived » M2M (model-to-model transformation) » how generate string from a Sequence of Tuple
| how generate string from a Sequence of Tuple [message #734859] |
Mon, 10 October 2011 04:19  |
Fi Fi Messages: 126 Registered: March 2010 |
I 'd generate from a Sequence of tuples a String
I try with this code
helper def : getinstancesname (instancesequence:Sequence (TupleType(position: Integer , instances : MetaModel!Instance))) : String =
instancesequence->iterate(t; y : String = 'a' |y+t.position.toString()+t.instance.name)
but that generate an Exception when I run Sad
please help me
thanks
[Updated on: Mon, 10 October 2011 04:33] Report message to a moderator
| Re: how generate string from a Sequence of Tuple [message #735176 is a reply to message #735027] |
Tue, 11 October 2011 03:23   |
I change the helper with the other attribute "position"
helper def : getinstancesname (instancesequence:Sequence (TupleType(position: Integer , instances : FiacreMetaModel!Instance))) : String =
instancesequence->iterate(t; y : String = 'a' |y+t.position.toString())
but that is the same exception
org.eclipse.m2m.atl.engine.emfvm.VMException
at getinstancesname#8(Instancie2Lie.atl[872:51-872:72])
local variables: self=Instancie2Lie : ASMModule, instancesequence=Sequence {Tuple {p = 1, i = FiacreModel!org.eclipse.emf.ecore.impl.DynamicEObjectImpl@2504e1f (eClass: org.eclipse.emf.ecore.impl.EClassImpl@15596774 (name: Name) (instanceClassName: null) (abstract: false, interface: false))}, Tuple {p = 1, i = FiacreModel!org.eclipse.emf.ecore.impl.DynamicEObjectImpl@6638d668 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@15596774 (name: Name) (instanceClassName: null) (abstract: false, interface: false))}, Tuple {p = 1, i = FiacreModel!org.eclipse.emf.ecore.impl.DynamicEObjectImpl@1d847a46 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@15596774 (name: Name) (instanceClassName: null) (abstract: false, interface: false))}, Tuple {p = 1, i = FiacreModel!org.eclipse.emf.ecore.impl.DynamicEObjectImpl@647798cd (eClass: org.eclipse.emf.ecore.impl.EClassImpl@15596774 (name: Name) (instanceClassName: null) (abstract: false, interface: false))}, Tuple {p = 1, i = FiacreModel!org.eclipse.emf.ecore.impl.DynamicEObjectImpl@67d0ee42 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@15596774 (name: Name) (instanceClassName: null) (abstract: false, interface: false))}, Tuple {p = 1, i = FiacreModel!org.eclipse.emf.ecore.impl.DynamicEObjectImpl@45ca644d (eClass: org.eclipse.emf.ecore.impl.EClassImpl@15596774 (name: Name) (instanceClassName: null) (abstract: false, interface: false))}, Tuple {p = 1, i = FiacreModel!org.eclipse.emf.ecore.impl.DynamicEObjectImpl@6a7f1f06 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@15596774 (name: Name) (instanceClassName: null) (abstract: false, interface: false))}, Tuple {p = 1, i = FiacreModel!org.eclipse.emf.ecore.impl.DynamicEObjectImpl@3fcdf989 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@15596774 (name: Name) (instanceClassName: null) (abstract: false, interface: false))}, Tuple {p = 1, i = FiacreModel!org.eclipse.emf.ecore.impl.DynamicEObjectImpl@6bb9b218 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@15596774 (name: Name) (instanceClassName: null) (abstract: false, interface: false))}}, y='a', t=Tuple {p = 1, i = FiacreModel!org.eclipse.emf.ecore.impl.DynamicEObjectImpl@2504e1f (eClass: org.eclipse.emf.ecore.impl.EClassImpl@15596774 (name: Name) (instanceClassName: null) (abstract: false, interface: false))}
at __applyTransition2Transition#60(Instancie2Lie.atl[484:11-484:142])
local variables: self=Instancie2Lie : ASMModule, link=TransientLink {rule = Transition2Transition, sourceElements = {transition_ins = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@76c6415a (eClass: org.eclipse.emf.ecore.impl.EClassImpl@68f35bd3 (name: Transition) (instanceClassName: null) (abstract: false, interface: false))}, targetElements = {transition_lie = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@2a42895e (eClass: org.eclipse.emf.ecore.impl.EClassImpl@45e83537 (name: Transition) (instanceClassName: null) (abstract: false, interface: false))}, variables = {}}, transition_ins=InstancieModel!<unnamed>, transition_lie=LieModel!<unnamed>
at __exec__#528(Instancie2Lie.atl)
local variables: self=Instancie2Lie : ASMModule, e=TransientLink {rule = Transition2Transition, sourceElements = {transition_ins = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@76c6415a (eClass: org.eclipse.emf.ecore.impl.EClassImpl@68f35bd3 (name: Transition) (instanceClassName: null) (abstract: false, interface: false))}, targetElements = {transition_lie = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@2a42895e (eClass: org.eclipse.emf.ecore.impl.EClassImpl@45e83537 (name: Transition) (instanceClassName: null) (abstract: false, interface: false))}, variables = {}}
at main#24(Instancie2Lie.atl)
Java Stack:
at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:643)
at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:388)
at org.eclipse.m2m.atl.engine.emfvm.ASM.run(ASM.java:208)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.internalLaunch(EMFVMLauncher.java:170)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMUILauncher.launch(EMFVMUILauncher.java:46)
at org.eclipse.m2m.atl.core.service.LauncherService.launch(LauncherService.java:136)
at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate.launchOrDebug(AtlLaunchConfigurationDelegate.java:300)
at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate.launch(AtlLaunchConfigurationDelegate.java:237)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:853)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:702)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:923)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1126)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: java.lang.NullPointerException
I 'd know how to navigate in a tuple
thanks
Current Time: Tue May 21 17:21:25 EDT 2013
Powered by FUDForum. Page generated in 0.07797 seconds
