Home » Eclipse Projects » Standard Widget Toolkit (SWT) » KTable Composite cell renderer
KTable Composite cell renderer [message #464162] Thu, 17 November 2005 09:52 Go to next message
Patrick Paulin is currently offline Patrick Paulin
Member
I'm interested in using KTable to support a display where there is one
cell per row, and that cell is rendered as an SWT Composite. I've been
looking at the cell renderer structure in KTable and I'm not sure this can
be made to work.
Has anyone done something similar, or is this just a dead end?
Patrick Paulin
patrick@marketcontours.com
www.marketcontours.com
Re: KTable Composite cell renderer [message #464197 is a reply to message #464162] Fri, 18 November 2005 10:32 Go to previous messageGo to next message
Lorenz Maierhofer is currently offline Lorenz Maierhofer
Member
I have no experience doing this - but I don't think that this would be a
problem.
I will try this with the existing cellrenderer interface and report
progress.
regards,
Lorenz
> can be made to work.
> Patrick Paulin
Re: KTable Composite cell renderer [message #464239 is a reply to message #464197] Fri, 18 November 2005 16:57 Go to previous messageGo to next message
Member
Did a simple test - it works but getting the event handling correct is a
small nightmare.
It would probably better to implement the desired behavior by drawing
the appropriate controls directly...
I would be interested in the use case for that - in what situations
would it help?
regards,
Lorenz
Lorenz Maierhofer wrote:
> problem.
> progress.
> regards,
> Lorenz
>> Thanks,
>> Patrick Paulin
Re: KTable Composite cell renderer [message #464259 is a reply to message #464239] Sat, 19 November 2005 04:55 Go to previous messageGo to next message
Ivan is currently offline Ivan
I'm interested in this way as well. I'm a Sybase PowerBuilder programmer
and
I'm get used to DataWindow which able to give you a very flexible way to
display
your data. Free style which mean you can place your column in anyway as
you like
and the grid is there if you prefer a very basic table style...
Thanks and i hope KTable able to do that. I like KTable very much!
Thanks for your all hardwork!
Re: KTable Composite cell renderer [message #464320 is a reply to message #464239] Mon, 21 November 2005 10:07 Go to previous messageGo to next message
Member
Hi Lorenz,
Thanks for looking into this. My use case is that I'd like to display
multiple (and very wide) diagrams for a set of financial instruments (e.g.
stocks). Each diagram is actually a GEF viewer, which requires a composite
parent. The diagram for each instrument would be displayed in a KTable
row. The user could resize rows to view the diagrams at a larger size.
If you're finding this difficult, I'm definitely going to look for a
different approach. I'll probably wind up placing the diagrams right onto
a composite and allow the user to resize them in some other way (zoom
button, or something like that).
If you think of a way to do this in KTable, I'd appreciate it. Thanks
again for your help.
Patrick Paulin
> small nightmare.
> would it help?
> regards,
> Lorenz
Re: KTable Composite cell renderer [message #639127 is a reply to message #464162] Mon, 15 November 2010 06:49 Go to previous messageGo to next message
Swapnil Sawant is currently offline Swapnil Sawant
Hi Lorenz/Patrick/Evan,
I am also in need of Composite cell renderer for KTable.
I wish to put ScrolledForm (or any other SWT widget) in each KTable cell.
Any sample code for this would be of great help to me.
Swapnil
Re: KTable Composite cell renderer [message #735478 is a reply to message #639127] Tue, 11 October 2011 20:25 Go to previous message
Raj  is currently offline Raj
Member
Are you doing this in RAP or RCP application.
Previous Topic:How to revalidate layout?
Next Topic:OS X: how to access system images
Current Time: Fri May 24 09:23:56 EDT 2013
Powered by FUDForum. Page generated in 0.01830 seconds
