Home » Eclipse Projects » EclipseLink » SQL to JPA
SQL to JPA [message #735185] Tue, 11 October 2011 03:37 Go to next message
Warus  is currently offline Warus
Hi.
In my database I have a table with 3 fields: field_1, field_2, field_3 and generated entity for that table. I need to implement something like this in EclipseLink:
Select (field_1/field_3) as field_1, (field_2/field_3) as field_2, field_3 from table;
Of course this is simplified example. Is there any way to do this without NativeQuery?
thanks for any help
Re: SQL to JPA [message #735396 is a reply to message #735185] Tue, 11 October 2011 11:40 Go to previous message
James is currently offline James
This should work in JPQL, did you try it? You will get back an Object[] of the three values.
Select (t.field_1/t.field_3), (t.field_2/t.field_3), t.field_3 from Table t
James : http://wiki.eclipse.org/EclipseLink : http://en.wikibooks.org/wiki/Java_Persistence : http://java-persistence-performance.blogspot.com/
Previous Topic:Eclipselink JPA merge problem
Next Topic:SQL to JPA
Current Time: Mon May 20 11:35:47 EDT 2013
Powered by FUDForum. Page generated in 0.34843 seconds
