| Re: Problem selecting by moue in Combo [message #735359 is a reply to message #735164] |
Tue, 11 October 2011 11:11  |
Rüdiger Herrmann Messages: 335 Registered: July 2009 |
can you reproduce the problem with a newer release of RAP? [1]
There is a newer service release of RAP 1.3: If you have to stick with
the 1.3 release, take 1.3.2. But apart from the 1.3 stream is not
maintained anymore.
RAP 1.4.1 is the latest stable release and RAP 1.5M2 is the latest
stable build.
If you can reproduce the problem with the latest build, please file a
bugzilla [2].
HTH
Rüdiger
[1] http://eclipse.org/rap/downloads/
[2] http://eclipse.org/rap/support/#new-bugs
On 11.10.2011 08:48, Manab wrote:
> We are using a org.eclipse.swt.widgets.Combo available in
> org.eclipse.rap.rwt_1.3.1.20100915-2301.jar. Sometimes in Internet
> Explorer when we try to select using mouse from a combo in my
> application it doesn't select anything. But if we use the keyboard
> arrows we are able to select.
> We checked for the same in Firefox. It works fine every time. Please
> suggest any solution for this issue.
> Kindly let me know if any other information is required.
Rüdiger Herrmann
Twitter: @EclipseRAP
FUDForum. Page generated in 0.16305 seconds
