Home » Eclipse Projects » Eclipse 4 » How to contribute to an E3 perspective with E4 Part.
How to contribute to an E3 perspective with E4 Part. [message #735267] Tue, 11 October 2011 07:29
keersbulik Missing name is currently offline keersbulik Missing name
I want to properly contribute to an E3 perspective with a Part realized in the E4 way.
I use E4 with compatibility layer and i launch "org.ui.ide.workbench.application" with the LegacyIDE.e4xmi. I also want the part i contribute appears in "ShowViewDialog".
I found a workaround consisting in adding an adapter on the E4 emf Model into an addon.
When the perpective is displayed i add my new part. But it's a crappy solution.
Is there a good solution for that ?
Thanks a lot.
Previous Topic:how to set minimum size for windows or parts
Next Topic:Correct use EModelService.findElements?
Current Time: Fri May 24 01:36:51 EDT 2013
Powered by FUDForum. Page generated in 0.01499 seconds
