Home » Modeling » Epsilon » validate option
validate option [message #734153] Thu, 06 October 2011 17:53 Go to next message
giovi  is currently offline giovi
Member
in tree editor generated with EMF i can see by right click on the root of tree an option to validate my model but i can't find it in my new editor generated with eugenia in RCP standard application or in normal mode. Where this feature is?
Re: validate option [message #734162 is a reply to message #734153] Thu, 06 October 2011 18:22 Go to previous messageGo to next message
Dimitris Kolovos is currently offline Dimitris Kolovos
Does this thread perhaps help? http://www.eclipse.org/forums/index.php?t=msg&th=169079
Dimitris
Re: validate option [message #734323 is a reply to message #734162] Fri, 07 October 2011 09:24 Go to previous messageGo to next message
Member
hi dimitris and tank you for quick reply!
The post you have suggested to me is more interesting but my problem is to localize default validation check who is present in emf tree editor. I read in Rcp mode there are some problems but in normal mode should be work... or not? i don't write any validation rules in EVL... i want to use just use simple validation feature that is already present in tree editor but in my GMF editor.
Re: validate option [message #734334 is a reply to message #734323] Fri, 07 October 2011 09:41 Go to previous messageGo to next message
In normal mode there should be a "Validate" item under the "Edit" menu.
Dimitris
Re: validate option [message #734338 is a reply to message #734334] Fri, 07 October 2011 09:55 Go to previous message
Member
Ok Ok forget my last question. I've forget to regenerate my diagram after i've turned on validation. In this way validation work in normal mode but in RCP mode is present validation option but problem view is missing and i can't see validation problems.... i suppose is the problem described in thread you have linked me, i hope to solve with it.
Previous Topic:The simplest ECL + EML example
Next Topic:labels new line character
Current Time: Wed May 22 16:21:52 EDT 2013
Powered by FUDForum. Page generated in 0.01833 seconds
