Home » Modeling » GMF (Graphical Modeling Framework) » parallel opened diagrams - delete not working
parallel opened diagrams - delete not working [message #732205] Tue, 04 October 2011 04:36 Go to next message
Eclipse User
Originally posted by: Lilija Klassen
I've a problem with the delete action when two diagrams are opened at
the same time. The problem occurrs when I add a new element and then try
to delete elements. While debugging I found out that the shape node of
the second openend diagram will not be deleted. This causes then a
recreation of edit parts and a nullpointer exception.
Any idea how to fix this?
Re: parallel opened diagrams - delete not working [message #734053 is a reply to message #732205] Thu, 06 October 2011 10:06 Go to previous messageGo to next message
Eclipse User
Am 04.10.2011 10:36, schrieb Lilija Klassen:
The two diagrams have also connections included, if i comment the
createConnection in the DiagramCanonicalEditPolicy out the delete action
works?
Has someone any idea why and how to fix this problem?
Lilija Klassen
Re: parallel opened diagrams - delete not working [message #734177 is a reply to message #734053] Thu, 06 October 2011 19:37 Go to previous messageGo to next message
Michael Golubev is currently offline Michael Golubev
Please post the stack trace and more details about how to reproduce the NPE here or into the new bugzilla.
Michael "Borlander" Golubev
Eclipse Committer (GMF, UML2Tools)
at Montages Think Tank, Prague, Czech Republic
Montages AG, Zürich, Switzerland
Re: parallel opened diagrams - delete not working [message #734230 is a reply to message #734177] Fri, 07 October 2011 03:38 Go to previous message
Eclipse User
Am 07.10.2011 01:37, schrieb Michael Golubev:
> Hello,
> Regards, Michael "Borlander" Golubev
here the stack trace. Note, that I did lots of customization. When I add
a new element into one of the two parallel opened diagrams I also create
connections. When I then delete the new added element or any other the
following stack trace occures.
!ENTRY org.eclipse.gmf.runtime.diagram.ui 4 4 2011-10-07 09:30:54.817
!MESSAGE execute
!STACK 0
org.eclipse.core.commands.ExecutionException: While executing the
operation, an exception occurred
org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:521)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack.execute(DiagramCommandStack.java:194)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack.execute(DiagramCommandStack.java:169)
org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.execute(DiagramAction.java:141)
de.wagner.tooling.incident.modeller.diagram.edit.commands.DeleteAction.doRun(DeleteAction.java:60)
org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandler.run(AbstractActionHandler.java:359)
org.eclipse.gmf.runtime.common.ui.action.ActionManager$1.run(ActionManager.java:225)
org.eclipse.gmf.runtime.common.ui.action.ActionManager.run(ActionManager.java:223)
org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandler.run(AbstractActionHandler.java:348)
at org.eclipse.gef.KeyHandler.performStroke(KeyHandler.java:83)
at org.eclipse.gef.KeyHandler.keyPressed(KeyHandler.java:55)
org.eclipse.gef.tools.SelectionTool.handleKeyDown(SelectionTool.java:331)
at org.eclipse.gef.tools.AbstractTool.keyDown(AbstractTool.java:1016)
at org.eclipse.gef.tools.SelectionTool.keyDown(SelectionTool.java:491)
at org.eclipse.gef.EditDomain.keyDown(EditDomain.java:169)
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchKeyPressed(DomainEventDispatcher.java:252)
org.eclipse.draw2d.LightweightSystem$EventHandler.keyPressed(LightweightSystem.java:497)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:167)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1104)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1100)
at org.eclipse.swt.widgets.Widget.wmKeyDown(Widget.java:1809)
at org.eclipse.swt.widgets.Control.WM_KEYDOWN(Control.java:4892)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4560)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4972)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2531)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3752)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at de.wagner.tooling.incident.Application.start(Application.java:45)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: java.lang.NullPointerException
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate(BasicEObjectImpl.java:1571)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1037)
de.wagner.tooling.incident.modeller.metamodel.impl.SwimlaneImpl.eGet(SwimlaneImpl.java:336)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1021)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1013)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1008)
de.wagner.tooling.incident.modeller.diagram.parsers.AbstractParser.getValue(AbstractParser.java:189)
de.wagner.tooling.incident.modeller.diagram.parsers.AbstractParser.getValues(AbstractParser.java:169)
de.wagner.tooling.incident.modeller.diagram.parsers.MessageFormatParser.getValues(MessageFormatParser.java:238)
de.wagner.tooling.incident.modeller.diagram.parsers.MessageFormatParser.getPrintString(MessageFormatParser.java:203)
de.wagner.tooling.incident.modeller.diagram.edit.parts.SceneStatusEditPart.getLabelText(SceneStatusEditPart.java:194)
de.wagner.tooling.incident.modeller.diagram.edit.parts.SceneStatusEditPart.refreshLabel(SceneStatusEditPart.java:385)
de.wagner.tooling.incident.modeller.diagram.edit.parts.SceneStatusEditPart.refreshVisuals(SceneStatusEditPart.java:374)
de.wagner.tooling.incident.modeller.diagram.edit.parts.SceneStatusEditPart.setLabel(SceneStatusEditPart.java:155)
de.wagner.tooling.incident.modeller.diagram.edit.parts.SceneEditPart.addFixedChild(SceneEditPart.java:132)
de.wagner.tooling.incident.modeller.diagram.edit.parts.SceneEditPart.addChildVisual(SceneEditPart.java:165)
org.eclipse.gef.editparts.AbstractEditPart.addChild(AbstractEditPart.java:211)
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.addChild(GraphicalEditPart.java:1319)
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(AbstractEditPart.java:781)
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractEditPart.java:726)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh(AbstractGraphicalEditPart.java:644)
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.access$3(GraphicalEditPart.java:1)
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart$3.run(GraphicalEditPart.java:861)
org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.runExclusive(TransactionalEditingDomainImpl.java:328)
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.refresh(GraphicalEditPart.java:851)
org.eclipse.gef.editparts.AbstractEditPart.addNotify(AbstractEditPart.java:253)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotify(AbstractGraphicalEditPart.java:223)
org.eclipse.gef.editparts.AbstractEditPart.addChild(AbstractEditPart.java:212)
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.refreshChild(GraphicalEditPart.java:1232)
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.handleMajorSemanticChange(GraphicalEditPart.java:1258)
org.eclipse.gmf.runtime.diagram.ui.editparts.ShapeEditPart.handleNotificationEvent(ShapeEditPart.java:165)
org.eclipse.gmf.runtime.diagram.ui.editparts.ShapeNodeEditPart.handleNotificationEvent(ShapeNodeEditPart.java:236)
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.notifyChanged(GraphicalEditPart.java:1438)
org.eclipse.gmf.runtime.diagram.core.listener.DiagramEventBroker.fireNotification(DiagramEventBroker.java:500)
org.eclipse.gmf.runtime.diagram.core.listener.DiagramEventBroker.resourceSetChanged(DiagramEventBroker.java:395)
org.eclipse.gmf.runtime.diagram.ui.DiagramEventBrokerThreadSafe.resourceSetChanged(DiagramEventBrokerThreadSafe.java:73)
org.eclipse.gmf.runtime.diagram.core.DiagramEditingDomainFactory$DiagramEditingDomain.postcommit(DiagramEditingDomainFactory.java:214)
org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.deactivate(TransactionalEditingDomainImpl.java:543)
org.eclipse.emf.transaction.impl.TransactionImpl.close(TransactionImpl.java:712)
org.eclipse.emf.transaction.impl.TransactionImpl.commit(TransactionImpl.java:474)
org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:155)
org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:513)
... 53 more
Previous Topic:Using GMF without code generation
Next Topic:XYAnchor to EllipseAnchor: is it possible?
Current Time: Sun May 19 10:21:32 EDT 2013
Powered by FUDForum. Page generated in 0.01636 seconds
