| SAXException when trying to run Leak Suspect report [message #729679] |
Mon, 26 September 2011 14:37  |
samlooker Messages: 7 Registered: September 2011 |
Junior Member |
I just have the MA 1.1.1 installed in my Eclipse 3.5.1 on a 64 bit windows server 2003. When I clicked the "Leak Suspects" link on a memory dump, I got below error. The eclipse has been working for months so it self is not a problem. Any help will be appreciated.
System property org.xml.sax.driver not specified (org.xml.sax.SAXException)
org.xml.sax.SAXException: System property org.xml.sax.driver not specified
at org.xml.sax.helpers.XMLReaderFactory.createXMLReader(Unknown Source)
at org.eclipse.mat.report.SpecFactory.read(SpecFactory.java:180)
at org.eclipse.mat.report.SpecFactory.create(SpecFactory.java:113)
at org.eclipse.mat.report.SpecFactory.create(SpecFactory.java:127)
at org.eclipse.mat.report.internal.RunRegisterdReport.execute(RunRegisterdReport.java:41)
at org.eclipse.mat.query.registry.ArgumentSet.execute(ArgumentSet.java:129)
at org.eclipse.mat.ui.QueryExecution$ExecutionJob.run(QueryExecution.java:174)
| Re: SAXException when trying to run Leak Suspect report [message #732037 is a reply to message #730764] |
Mon, 03 October 2011 14:54   |
Junior Member |
Neither worked. Please see my .ini and log below.
I loaded the standalone version on my 32 bit native 2003 server, and it worked fine on the same dump file.
Only on my 64 bit VMware 2003 server it is not working.
Thanks for your help.
MemoryAnalyzer.ini
-vm
C:\Program Files\Java\jdk1.6.0_11\bin
-vmargs
-Dorg.xml.sax.parser=org.apache.xerces.parsers.SAXParser -Xmx1024m -XX:MaxPermSize=192m
log:
!SESSION 2011-09-27 14:54:10.402 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_11
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86_64
!ENTRY org.eclipse.mat.ui 1 0 2011-09-27 14:55:33.246
!MESSAGE Heap C:\ColdFusion8\runtime\bin\java_pid4288.hprof contains 1,556,832 objects
!ENTRY org.eclipse.mat.ui 4 0 2011-09-27 14:57:40.683
!MESSAGE java.io.IOException
!STACK 0
org.eclipse.mat.SnapshotException: java.io.IOException
at org.eclipse.mat.SnapshotException.rethrow(SnapshotException.java:74)
at org.eclipse.mat.query.registry.ArgumentSet.execute(ArgumentSet.java:153)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: java.io.IOException
at org.eclipse.mat.report.SpecFactory.read(SpecFactory.java:188)
... 2 more
Caused by: org.xml.sax.SAXException: System property org.xml.sax.driver not specified
... 6 more
!SUBENTRY 1 org.eclipse.mat.ui 4 0 2011-09-27 14:57:40.683
!MESSAGE Exception of type java.io.IOException
!STACK 0
java.io.IOException
... 6 more
!MESSAGE System property org.xml.sax.driver not specified (org.xml.sax.SAXException)
!STACK 0
!SESSION 2011-09-27 16:28:19.596 -----------------------------------------------
Framework arguments: -vm C:\Program Files\Java\jdk1.6.0_11\bin
Command-line arguments: -os win32 -ws win32 -arch x86_64 -vm C:\Program Files\Java\jdk1.6.0_11\bin
!ENTRY org.eclipse.mat.ui 4 0 2011-09-27 16:29:25.674
!STACK 0
... 2 more
... 6 more
!SUBENTRY 1 org.eclipse.mat.ui 4 0 2011-09-27 16:29:25.674
!STACK 0
java.io.IOException
... 6 more
!STACK 0
!SESSION 2011-09-27 16:35:24.901 -----------------------------------------------
Framework arguments: -vmC:\Program Files\Java\jdk1.6.0_11\bin
Command-line arguments: -os win32 -ws win32 -arch x86_64 -vmC:\Program Files\Java\jdk1.6.0_11\bin
!ENTRY org.eclipse.mat.ui 4 0 2011-09-27 16:35:54.745
!STACK 0
... 2 more
... 6 more
!SUBENTRY 1 org.eclipse.mat.ui 4 0 2011-09-27 16:35:54.745
!STACK 0
java.io.IOException
... 6 more
!STACK 0
FUDForum. Page generated in 0.01973 seconds
