| Mysterious service problem [message #733651] |
Wed, 05 October 2011 05:59  |
Barbara Rosi-Schwartz Messages: 448 Registered: July 2009 |
Hello everyone.
I have a weird problem related to a registered OSGi service that I have been poring over for a day now without finding my bug. I am wondering if anybody can spot the problem or give me a hint on how to continue to pursue it.
I have an OSGi service which I register with the registry via SpringDM. When I start things up, I can see the service being ready and available.
I then start 3 bundles which require this service: two of them find it (again via SpringDM) without a problem, but the third one claims the bean representing the service cannot be found and produces and exception.
All Spring declarative clauses and java code in the clients is exactly the same in the three cases.
Any high level hints on how to pursue this further?
TIA,
B.
| Re: Mysterious service problem [message #733690 is a reply to message #733659] |
Wed, 05 October 2011 08:39   |
I can see that the DefaultListableBeanFactory class has a couple of service type beans in its beanDefinitionMap, but none of them has my given name, rather something like "org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#0".
What am I missing here?
Anyway, so much for my musings. Here's the exception stack trace, Glyn:
Exception in thread "region-dm-1" org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accountopening' defined in URL [bundleentry://99.fwk518144827/META-INF/spring/workbench.accounts.accountopening-context.xml]: Cannot resolve reference to bean 'winmanService' while setting bean property 'winmanService'; nested exception is org.springframework.beans.factory.NoSuchBeanDefinitionException: No bean named 'winmanService' is defined
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:328)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:106)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1325)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1086)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:291)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:288)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:190)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:580)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:895)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:69)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:355)
at org.springframework.osgi.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:320)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:132)
at org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor$2.run(ContextPropagatingTaskExecutor.java:95)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Caused by: org.springframework.beans.factory.NoSuchBeanDefinitionException: No bean named 'winmanService' is defined
at org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeanDefinition(DefaultListableBeanFactory.java:527)
at org.springframework.beans.factory.support.AbstractBeanFactory.getMergedLocalBeanDefinition(AbstractBeanFactory.java:1083)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:274)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:322)
... 20 more
Thanks!
[Updated on: Wed, 05 October 2011 09:06] Report message to a moderator
FUDForum. Page generated in 0.02569 seconds
