Home » Modeling » MoDisco » VB6 Reverse Engineering
VB6 Reverse Engineering [message #729914] Tue, 27 September 2011 05:25 Go to next message
marco.paparusso is currently offline marco.paparusso
I'm completely new to MoDisco and I'm trying to gather info about it to find out if it can help me out.
My purpose is to do some reverse engineering of a Visual Basic 6 application and extract some WebML or Conallen's WAE models, in order to act a refactoring of our application to improve the user experience and renew the presentation layer.
My first question is: does MoDisco support VB6 code? I've read something about it (www.eclipse.org/MoDisco/useCases/VBCodeAnalysis/) but it seems like a dead end. I understood that a VB6 discoverer is needed. Does it exist?
The second question is about Modisco's output: assuming it can support VB6, what kind of model can I get? I've seen an example where the result was the generation of some UML class diagrams. It would be kinda poor and not so helpful.
Please, help me out!
Calla.
Re: VB6 Reverse Engineering [message #729989 is a reply to message #729914] Tue, 27 September 2011 08:31 Go to previous messageGo to next message
Gregoire Dupe is currently offline Gregoire Dupe
Member
No, there isn't any support of VB6.
It's a too old page, if Hugo agrees, I'll remove it.
Currently, we only have an example that read Java code and produces a UML model, but not the corresponding diagrams (cf. http://download.eclipse.org/modeling/mdt/modisco/doc/org.eclipse.modisco.usecase.modelfilter.doc/mediawiki/user.html).
In the MoDisco project we begin by discovering a model representing the code (for example a model conforming to the Java model, http://help.eclipse.org/indigo/topic/org.eclipse.gmt.modisco.java.doc/doc/MoDisco/Components/Java/Documentation/0.9/0.9.html). After, we transform this code model to a UML model, a KDM model or something else.
Gregoire Dupe
Re: VB6 Reverse Engineering [message #730353 is a reply to message #729989] Wed, 28 September 2011 04:33 Go to previous messageGo to next message
Hugo Bruneliere is currently offline Hugo Bruneliere
Hello Marco,
First, thanks a lot for your interest in MoDisco.
The page mentioned by Grégoire is now deprecated and so could be definitely removed (even though it is already not referenced anymore from the MoDisco homepage and Wiki, please could you inform us if you found a remaining link?).
Anyway, generally speaking, the process "source code -> source model -> transformed model 1 -> etc" as described in the previous answer is the one followed by the MoDisco approach and framework.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
Re: VB6 Reverse Engineering [message #733643 is a reply to message #730353] Wed, 05 October 2011 05:36 Go to previous message
Thanks for your helpful replies.
@Hugo: I just googled "vb6 modisco" and I got there.
Previous Topic:How to create eclipse like Welcome page
Next Topic:Feature request:: Listener to InventoryModel creation
Current Time: Sun May 26 05:43:04 EDT 2013
Powered by FUDForum. Page generated in 0.01695 seconds
