File is out of sync problem [message #733510] |
Tue, 04 October 2011 18:37 |
Tom Messages: 16 Registered: April 2010 |
Junior Member |
I have a web project that,as part of it's Maven (M2E) build, writes a file "version.properties" directly to the /target/classes/properties folder.
The Eclipse clean/build process works correctly, and I can publish to tomcat for debugging. However, if I touch ANYTHING and then attempt to republish to tomcat, I get the following error:
Resource is out of sync with the file system: '/MyProject/target/classes/properties/version.properties'.
Can someone at least point me in the right direction here? What is tripping Eclipse up and making it think this file is out of sync?
FUDForum. Page generated in 0.01633 seconds
