Home » Eclipse Projects » DTP » More than one select statement in SQL scrapbook?
More than one select statement in SQL scrapbook? [message #718000] Mon, 22 August 2011 20:50 Go to next message
Brian Lavender is currently offline Brian Lavender
I have a data connection to Oracle. I tried putting in more than one select query in the SQL scrapbook, but when I run it, it gives me an error. Yet in another version of Eclipse, the two statements run just fine. I take it that there must be a parameter I have set differently between the two. Any suggestions?
brian
Re: More than one select statement in SQL scrapbook? [message #733502 is a reply to message #718000] Tue, 04 October 2011 17:50 Go to previous message
Brian Payton is currently offline Brian Payton
What is the error you are getting? And can you give an example of the
statements?
> brian
Previous Topic:SQL scrapbook parse Oracle SQL and tell where there is an error?
Next Topic:stored procedure debugging
Current Time: Fri May 24 10:31:29 EDT 2013
Powered by FUDForum. Page generated in 0.07509 seconds
