Home » Modeling » Epsilon » The simplest ECL + EML example
The simplest ECL + EML example [message #731678] Sun, 02 October 2011 08:30 Go to next message
Eclipse User is currently offline Eclipse User
Can someone reply with the necessary code to merge the following model:
Box---[0..*]->Things where the reference is named 'things' and is a
containment relationship.
Attached are two simple model instances, the target model and the metamodel.
-H
  • Attachment: one.model
    (Size: 0.32KB, Downloaded 62 times)
  • Attachment: target.model
    (Size: 0.14KB, Downloaded 61 times)
  • Attachment: two.model
    (Size: 0.26KB, Downloaded 60 times)
  • Attachment: model.ecore
    (Size: 0.84KB, Downloaded 72 times)
Re: The simplest ECL + EML example [message #731852 is a reply to message #731678] Mon, 03 October 2011 06:27 Go to previous messageGo to next message
Dimitris Kolovos is currently offline Dimitris Kolovos
This example should help: http://eclipse.org/gmt/epsilon/examples/index.php?example=org.eclipse.epsilon.examples.oomerging
If not, please let me know and I'll have a look at your example.
Dimitris
Re: The simplest ECL + EML example [message #732048 is a reply to message #731852] Mon, 03 October 2011 14:40 Go to previous message
On 10/03/2011 12:27 PM, Dimitris Kolovos wrote:
> Cheers,
> Dimitris
Thank you. It works.
-H
Previous Topic:[EML] Standalone: Match Trace from other module
Next Topic:validate option
Current Time: Sun May 19 01:36:14 EDT 2013
Powered by FUDForum. Page generated in 0.01561 seconds
