Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Can DateTime widget display hours in 24-hour format?
Can DateTime widget display hours in 24-hour format? [message #728289] Thu, 22 September 2011 18:16 Go to next message
Herb Miller is currently offline Herb Miller
I need a DateTime widget to display the hours in a 24-hour format (e.g. 7:00 p.m. = 19:00). Is that possible?
Herb Miller
Re: Can DateTime widget display hours in 24-hour format? [message #728524 is a reply to message #728289] Fri, 23 September 2011 08:15 Go to previous messageGo to next message
Lakshmi Shanmugam
The DateTime widget automatically displays the time in the 24-hour or 12-hour format based on your system's settings.
Lakshmi P Shanmugam
Re: Can DateTime widget display hours in 24-hour format? [message #731384 is a reply to message #728524] Fri, 30 September 2011 15:38 Go to previous messageGo to next message
So, if my system settings are 12 hour format, the DateTime widget will not display the 24 hour format. Doesn't that seem a little restrictive?
Herb MIller
Re: Can DateTime widget display hours in 24-hour format? [message #731894 is a reply to message #731384] Mon, 03 October 2011 08:27 Go to previous message
Lakshmi Shanmugam
I did a quick search and found a related bug asking for 24hrs format in DateTime widget --> https://bugs.eclipse.org/bugs/show_bug.cgi?id=337468.
The current behavior is to use the format and locale from the system. You could comment on the bug with your requirements/questions.
Lakshmi P Shanmugam
Previous Topic:Change SWT List selection color
Next Topic:dragging a TreeColumn
Current Time: Thu May 23 18:57:08 EDT 2013
Powered by FUDForum. Page generated in 0.01627 seconds
