| use JSF2 with SNAPS [message #731697] |
Sun, 02 October 2011 10:48  |
Ted Pan Messages: 2 Registered: October 2011 Location: Canada |
Junior Member |
hi,
I'm trying to use JSF2 with VS. But the Snap could not be started successfully, while the host module, which is using JSF2 as well, could be started successfully.
I got the following exception in the log file:
[2011-10-01 19:36:06.854] ERROR iLogServiceListener@2f6a23cf org.osgi.service.log.LogService Bundle org.eclipse.osgi_3.7.0.v20110613, An unexpected runtime error has occurred. java.lang.IllegalStateException: Application was not properly initialized at startup, could not find Factory: javax.faces.context.FacesContextFactory
at javax.faces.FactoryFinder$FactoryManager.getFactory(FactoryFinder.java:951)
at javax.faces.FactoryFinder.getFactory(FactoryFinder.java:316)
at javax.faces.webapp.FacesServlet.init(FacesServlet.java:302)
at org.eclipse.virgo.snaps.core.internal.webapp.container.ServletManager$1.doWithClassLoader(ServletManager.java:71)
at org.eclipse.virgo.snaps.core.internal.webapp.container.ServletManager$1.doWithClassLoader(ServletManager.java:1)
at org.eclipse.virgo.snaps.core.internal.webapp.container.ManagerUtils.doWithThreadContextClassLoader(ManagerUtils.java:36)
at org.eclipse.virgo.snaps.core.internal.webapp.container.ServletManager.init(ServletManager.java:65)
at org.eclipse.virgo.snaps.core.internal.webapp.container.StandardVirtualContainer.init(StandardVirtualContainer.java:85)
at org.eclipse.virgo.snaps.core.internal.webapp.WebAppSnap.init(WebAppSnap.java:105)
at org.eclipse.virgo.snaps.core.internal.SnapFactoryMonitor$SnapBinder.hostPublished(SnapFactoryMonitor.java:170)
at org.eclipse.virgo.snaps.core.internal.SnapFactoryMonitor$SnapBinder.serviceChanged(SnapFactoryMonitor.java:239)
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:104)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:861)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:819)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:771)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:130)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:214)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:433)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:451)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:950)
at org.eclipse.gemini.web.internal.StandardWebApplication.publishServletContext(StandardWebApplication.java:142)
at org.eclipse.gemini.web.internal.StandardWebApplication.start(StandardWebApplication.java:92)
at org.eclipse.virgo.web.core.internal.WebBundleLifecycleListener.onStarted(WebBundleLifecycleListener.java:122)
at org.eclipse.virgo.kernel.install.artifact.internal.StandardArtifactStateMonitor.onStarted(StandardArtifactStateMonitor.java:247)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.asyncStartSucceeded(AbstractInstallArtifact.java:294)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.access$0(AbstractInstallArtifact.java:291)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$StateMonitorSignal.signalSuccessfulCompletion(AbstractInstallArtifact.java:229)
at org.eclipse.virgo.kernel.core.internal.BundleStartTracker$1.run(BundleStartTracker.java:143)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
[2011-10-01 19:36:06.886] ERROR iLogServiceListener@2f6a23cf org.osgi.service.log.LogService Bundle testJSF2-subproject_1.0.0, FrameworkEvent ERROR java.lang.IllegalStateException: Application was not properly initialized at startup, could not find Factory: javax.faces.context.FacesContextFactory
the web.xml is very simple:
<context-param>
<description>State saving method: 'client' or 'server' (=default). See JSF Specification 2.5.2</description>
<param-name>javax.faces.STATE_SAVING_METHOD</param-name>
<param-value>server</param-value>
</context-param>
<context-param>
<param-name>javax.servlet.jsp.jstl.fmt.localizationContext</param-name>
<param-value>resources.application</param-value>
</context-param>
<listener>
<listener-class>com.sun.faces.config.ConfigureListener</listener-class>
</listener>
<servlet>
<servlet-name>Faces Servlet</servlet-name>
<servlet-class>javax.faces.webapp.FacesServlet</servlet-class>
<load-on-startup>1</load-on-startup>
</servlet>
<servlet-mapping>
<url-pattern>*.xhtml</url-pattern>
</servlet-mapping>
and the MANIFEST.MF
Manifest-Version: 1.0
Class-Path:
Bundle-Version: 1.0.0
Bundle-Name: TestJSF2_subproject
Bundle-ManifestVersion: 2
Bundle-SymbolicName: testJSF2-subproject
Snap-Host: testJSF2;version=1.0.0
Snap-ContextPath: /sub1
Bundle-ClassPath: WEB-INF/classes
Require-Bundle: org.glassfish.com.sun.faces
Import-Bundle: com.springsource.org.apache.taglibs.standard;version="[
1.1.2,2.1.2)",org.eclipse.virgo.snaps.api;version="[3.0.0,3.1)"
Import-Package: javax.servlet.jsp.jstl.core;version="[1.2.0,2.2.0)",or
g.eclipse.virgo.snaps.core;version="[3.0.0,3.1)", org.osgi.framework;version=1.3,
javax.servlet;version=2.5.0,org.eclipse.gemini.web.core
any idea?
Thanks in advance.
[Updated on: Mon, 03 October 2011 08:54] Report message to a moderator
| Re: use JSF2 with SNAPS [message #733801 is a reply to message #733788] |
Wed, 05 October 2011 12:58  |
Junior Member |
thanks Chris.
I had tried the case you mentioned. Both of the modules( host module, and subproject module) worked well if I removed the SNAP manifest headers from subproject module. they works well as independent JSF modules.
And if I remove JSF servlet declaration in web.xml of subproject module,
<servlet>
</servlet>
<servlet-mapping>
</servlet-mapping>
the host and snap module(subproject) works well. the host works as JSF module, but subproject works as web module without JSF support.
[Updated on: Wed, 05 October 2011 13:00] Report message to a moderator
FUDForum. Page generated in 0.01737 seconds
