Home » Eclipse Projects » Standard Widget Toolkit (SWT) » TreeViewer with only one TreeViewerColumn(How to have it resize automatically?)
TreeViewer with only one TreeViewerColumn [message #731675] Sun, 02 October 2011 08:13 Go to next message
sielver Missing name is currently offline sielver Missing name
Member
So I have a TreeViewer and I want to add editing support to it.
I used to use the setCellEditors/setCellModifier methods directly on my TreeViewer instance but I noticed the setEditingSupport was the new, preferred way of doing this (and it seems more handy):
// In my TreeViewer constructor
TreeViewerColumn column = new TreeViewerColumn(this, SWT.NONE);
column.setEditingSupport(new EditingSupport(this));
column.setLabelProvider(new LabelProvider());
column.getColumn().setText("Column 1");
column.getColumn().setWidth(???); // Here's the question
So I have to specify a witdh for the column to be visible. Is there an easy way to have it take the full size of the tree all the time? I heard about adding some listeners and calling pack() on the TreeColumn but I'm not sure how to do that, and I wonder if there's anything handier.
Any idea?
-Jérémy
[Updated on: Sun, 02 October 2011 08:13]
Report message to a moderator
Re: TreeViewer with only one TreeViewerColumn [message #731680 is a reply to message #731675] Sun, 02 October 2011 08:52 Go to previous messageGo to next message
Member
OK, answering myself as I found the solution:
ViewerColumn column = new ViewerColumn(this, getTree()) {};
column.setLabelProvider(labelProvider);
Basically, using a ViewerColumn instance directly doesn't create a TreeColumn behind, i.e. no need to specify a size or whatever.
Re: TreeViewer with only one TreeViewerColumn [message #731843 is a reply to message #731680] Mon, 03 October 2011 05:29 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
Though this works it this is not how we intended to use ViewerColumn, i
think we simply missed ColumnViewer#setEditingSupport(). So please file
a bugzilla to request this API.
Tom
Am 02.10.11 14:52, schrieb sielver:
Re: TreeViewer with only one TreeViewerColumn [message #731919 is a reply to message #731843] Mon, 03 October 2011 09:48 Go to previous messageGo to next message
Member
Done:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=359708
Re: TreeViewer with only one TreeViewerColumn [message #738495 is a reply to message #731919] Sun, 16 October 2011 06:01 Go to previous message
Member
Expanding on this:
Still using a simple one-column TreeViewer with no explicit TreeColumn, I would like the whole row's background to be painted when overriding the getBackground() method of my LabelProvider. Is there any easy way to achieve this?
Jérémy
Previous Topic:huge polyline performance
Next Topic:Custom Tree Selection mechanism
Current Time: Sun May 19 16:59:10 EDT 2013
Powered by FUDForum. Page generated in 0.01896 seconds
