Home » Eclipse Projects » Web Tools Project (WTP) » Import WSDL and XSD files
Import WSDL and XSD files [message #731054] Thu, 29 September 2011 15:11
Angel  is currently offline Angel
Hi.
I'm try to import a WSDL and XSD files from Web Service with the Web Service Explorer, but i only can import WSDL file, Web Service Explorer doesn't import XSD files.
The web service is:
ht_tp://wcf.3marketeers.com/service.svc?wsdl
And when i open WSDL in Web Service Explorer y get this error:
IWAB0380E Errors were encountered while validating XML schemas.
XSD: The location 'ht_tp:// wcf.3marketeers.com/service.svc?xsd=xsd1' has not been resolved because the import is unused
XSD: There is no xmlns declaration for namespace 'ht_tp:// schemas.microsoft.com/2003/10/Serialization/'
XSD: The location 'ht_tp:// wcf.3marketeers.com/service.svc?xsd=xsd2' has not been resolved because the import is unused
XSD: There is no xmlns declaration for namespace 'ht_tp:// schemas.datacontract.org/2004/07/WCFServices'
XSD: The location 'ht_tp:// wcf.3marketeers.com/service.svc?xsd=xsd3' has not been resolved because the import is unused
XSD: There is no xmlns declaration for namespace 'ht_tp:// schemas.microsoft.com/2003/10/Serialization/Arrays'
XSD: The pattern facet is not permitted in a type based on 'ht_tp:// www.w3.org/2001/XMLSchema#duration'
XSD: The minInclusive facet is not permitted in a type based on 'ht_tp:// www.w3.org/2001/XMLSchema#duration'
XSD: The maxInclusive facet is not permitted in a type based on 'ht_tp:// www.w3.org/2001/XMLSchema#duration'
XSD: The pattern facet is not permitted in a type based on 'ht_tp:// www.w3.org/2001/XMLSchema#string'
IWAB0381I ht_tp:// wcf.3marketeers.com/service.svc?wsdl was successfully opened.
I try with Netbeans and it downloads all files.
How i can import WSDL and XSD files with Web Service Explorer?
Thanks.
Previous Topic:Not Seeing 'faces config editor'
Next Topic:URIResolverExtension / custom Resolvers
Current Time: Mon May 20 08:48:28 EDT 2013
Powered by FUDForum. Page generated in 0.02077 seconds
