Home » Eclipse Projects » EclipseLink » eclipselink generates table on the wrong schema
eclipselink generates table on the wrong schema [message #730635] Wed, 28 September 2011 14:43 Go to next message
Luiz E. is currently offline Luiz E.
Member
hi all.
i have a relation like this
@Entity
@Table(schema="ecf")
public class ImpressoraFiscal implements Serializable{
	private static final long serialVersionUID = 6246259319048104042L;
	@OneToMany(cascade={CascadeType.ALL}, orphanRemoval=true)
	private List<Aliquota> aliquotas = new ArrayList<Aliquota>();
and
@Entity
public class Aliquota implements Serializable {
	private static final long serialVersionUID = -1473589350884030504L;
	@Id @GeneratedValue(strategy=GenerationType.IDENTITY)
	private Long id;
and as you can see, both table are in 'ecf' schema. this kind of relationship generates a table like 'ImpressoraFiscal_Aliquota'. so far, everything is ok
but this is weird: this table 'ImpressoraFiscal_Aliquota' is generated on 'public' schema (i'm using postgre)
is this the expected behavior?
thanks in advanced
Re: eclipselink generates table on the wrong schema [message #730876 is a reply to message #730635] Thu, 29 September 2011 08:09 Go to previous messageGo to next message
Guy Pelletier is currently offline Guy Pelletier
The behavior is correct since you are allowing the join table to default on the OneToMany. You'll need to add @JoinTable(schema="ecf") to have it in the same schema.
Alternatively, you can specify a schema default in XML under the <persistence-unit-defaults> to apply to all your tables.
Guy
Re: eclipselink generates table on the wrong schema [message #731043 is a reply to message #730876] Thu, 29 September 2011 14:43 Go to previous message
Member
thank you!
the @JoinTable did the trick!
Previous Topic:Problem JRE up to 6u18 on Java Web Start
Next Topic:eclipselink generates table on the wrong schema
Current Time: Tue May 21 07:31:30 EDT 2013
Powered by FUDForum. Page generated in 0.01606 seconds
