Home » Modeling » EMF » [CDO] ClassCastException with CDO-Hibernate
| [CDO] ClassCastException with CDO-Hibernate [message #730404] |
Wed, 28 September 2011 06:25  |
Missing name Missing name Messages: 17 Registered: September 2011 |
Junior Member |
Hello again. I am executing this code:
static public void testFullSave(ResourceSet rs, String sourceFile,
String resourceName, boolean legacyMode) {
Resource r = rs
.getResource(URI.createFileURI(new File(sourceFile)
.getAbsolutePath()), true);
List<EObject> roots = r.getContents();
CDOSessionConfiguration sessionConfiguration = initialize();
if (legacyMode) {
CDOUtil.setLegacyModeDefault(true);
CDOSession session = openSession(sessionConfiguration);
long l = System.currentTimeMillis();
CDOTransaction transaction = session.openTransaction();
CDOResource resource = transaction.getOrCreateResource(resourceName); //$NON-NLS-1$
resource.getContents().clear();
resource.getContents().addAll(roots);
try {
transaction.commit();
System.err.println("FULL SAVE TIME: "
+ (System.currentTimeMillis() - l));
} catch (CommitException e) {
System.err.println("FULL SAVE TIME UNTIL ERROR: "
e.printStackTrace();
transaction.close();
session.close();
System.exit(0);
which stores a model in a CDO Hibernate 4.0 repository over MySQL. The same code and example model worked fine in CDO 4.0 but now it throws a ClassCastException on the server:
Hibernate: insert into `cdoresourcenode` (e_version, resource_id, container_id, `name`, `dtype`) values (?, ?, ?, ?, 'CDOResource')
Hibernate: insert into `core_physicalelement` (resource_id, container_id, version, `path`, `isreadonly`, dtype) values (?, ?, ?, ?, ?, 'core.IJavaModel')
[ERROR] java.lang.String cannot be cast to java.lang.Boolean
java.lang.ClassCastException: java.lang.String cannot be cast to java.lang.Boolean
at org.hibernate.type.descriptor.java.BooleanTypeDescriptor.unwrap(BooleanTypeDescriptor.java:36)
at org.hibernate.type.descriptor.sql.BitTypeDescriptor$1.doBind(BitTypeDescriptor.java:55)
at org.hibernate.type.descriptor.sql.BasicBinder.bind(BasicBinder.java:89)
at org.hibernate.type.AbstractStandardBasicType.nullSafeSet(AbstractStandardBasicType.java:282)
at org.hibernate.type.AbstractStandardBasicType.nullSafeSet(AbstractStandardBasicType.java:277)
at org.hibernate.type.AbstractSingleColumnStandardBasicType.nullSafeSet(AbstractSingleColumnStandardBasicType.java:85)
at org.hibernate.persister.entity.AbstractEntityPersister.dehydrate(AbstractEntityPersister.java:2166)
at org.hibernate.persister.entity.AbstractEntityPersister.dehydrate(AbstractEntityPersister.java:2143)
at org.hibernate.persister.entity.AbstractEntityPersister$4.bindValues(AbstractEntityPersister.java:2321)
at org.hibernate.id.insert.AbstractReturningDelegate.performInsert(AbstractReturningDelegate.java:56)
at org.hibernate.persister.entity.AbstractEntityPersister.insert(AbstractEntityPersister.java:2327)
at org.hibernate.persister.entity.AbstractEntityPersister.insert(AbstractEntityPersister.java:2834)
at org.hibernate.action.EntityIdentityInsertAction.execute(EntityIdentityInsertAction.java:71)
at org.hibernate.engine.ActionQueue.execute(ActionQueue.java:273)
at org.hibernate.event.def.AbstractSaveEventListener.performSaveOrReplicate(AbstractSaveEventListener.java:320)
at org.hibernate.event.def.AbstractSaveEventListener.performSave(AbstractSaveEventListener.java:203)
at org.hibernate.event.def.AbstractSaveEventListener.saveWithGeneratedId(AbstractSaveEventListener.java:129)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.saveWithGeneratedOrRequestedId(DefaultSaveOrUpdateEventListener.java:210)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.entityIsTransient(DefaultSaveOrUpdateEventListener.java:195)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.performSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:117)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.onSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:93)
at org.hibernate.impl.SessionImpl.fireSaveOrUpdate(SessionImpl.java:685)
at org.hibernate.impl.SessionImpl.saveOrUpdate(SessionImpl.java:677)
at org.hibernate.engine.CascadingAction$5.cascade(CascadingAction.java:252)
at org.hibernate.engine.Cascade.cascadeToOne(Cascade.java:392)
at org.hibernate.engine.Cascade.cascadeAssociation(Cascade.java:335)
at org.hibernate.engine.Cascade.cascadeProperty(Cascade.java:204)
at org.hibernate.engine.Cascade.cascadeCollectionElements(Cascade.java:425)
at org.hibernate.engine.Cascade.cascadeCollection(Cascade.java:362)
at org.hibernate.engine.Cascade.cascadeAssociation(Cascade.java:338)
at org.hibernate.engine.Cascade.cascade(Cascade.java:161)
at org.hibernate.event.def.AbstractSaveEventListener.cascadeAfterSave(AbstractSaveEventListener.java:475)
at org.hibernate.event.def.AbstractSaveEventListener.performSaveOrReplicate(AbstractSaveEventListener.java:353)
at org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.doWrite(HibernateStoreAccessor.java:679)
at org.eclipse.emf.cdo.spi.server.StoreAccessorBase.write(StoreAccessorBase.java:149)
at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:425)
at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:42)
at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:1)
at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:96)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:244)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:92)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:109)
at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:84)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:90)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:326)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:63)
at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:63)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:251)
at org.eclipse.net4j.signal.Signal.run(Signal.java:147)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
core_physicalelement is the table that corresponds to the abstract superclass of the root of model.
Since both the source XMI model and the generated Java classes worked correctly with CDO 4.0 and other EMF software I assume that there is nothing wrong with them. Could it be a problem of the generated Hibernate Mapping?
I have also generated a Hibernate Mapping with the org.eclipse.emf.cdo.examples.hibernate.client.GenerateHBMTest test class. The relevant excerpt of the mapping is:
<hibernate-mapping auto-import="false">
<class entity-name="IJavaElement" abstract="true" lazy="true" table="`ijavaelement`">
<meta attribute="eclassName" inherit="false">IJavaElement</meta>
<meta attribute="epackage" inherit="false">org.amma.dsl.jdt.core</meta>
<tuplizer entity-mode="pojo" class="org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDORevisionTuplizer"/>
<tuplizer entity-mode="dynamic-map" class="org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDORevisionTuplizer"/>
<id type="long" name="idcol" column="idcol" access="org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDOSyntheticIdPropertyHandler">
<meta attribute="syntheticId" inherit="false">true</meta>
<generator class="native"/>
</id>
<property name="resourceID" type="org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDOIDUserType">
<column name="resource_id"/>
</property>
<property name="containerID" type="string">
<column name="container_id"/>
</property>
<property name="version" type="java.lang.Integer">
<meta attribute="version">true</meta>
<column name="version"/>
</property>
<property name="elementName" lazy="false" insert="true" update="true" not-null="true" unique="false" type="java.lang.String">
<column not-null="true" unique="false" name="`elementname`"/>
</property>
</class>
<class entity-name="PhysicalElement" abstract="true" lazy="true" table="`physicalelement`">
<meta attribute="eclassName" inherit="false">PhysicalElement</meta>
</id>
</property>
</property>
</property>
<property name="path" lazy="false" insert="true" update="true" not-null="true" unique="false" type="java.lang.String">
<column not-null="true" unique="false" name="`path`"/>
</property>
<property name="isReadOnly" lazy="false" insert="true" update="true" not-null="true" unique="false" type="java.lang.Boolean">
<column not-null="true" unique="false" name="`isreadonly`"/>
</property>
</class>
<joined-subclass entity-name="IJavaModel" abstract="false" lazy="true" extends="PhysicalElement" table="`ijavamodel`">
<meta attribute="eclassName" inherit="false">IJavaModel</meta>
<key>
<column name="`physicalelement_e_id`"/>
</key>
<list name="javaProjects" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="ijavamodel_javaprojects">
<column name="`ijavamodel_javaprojects_e_id`" not-null="false" unique="false" index="IJavaModel_javaProjects"/>
</key>
<list-index column="`ijavamodel_javaprojects_idx`"/>
<one-to-many entity-name="IJavaProject"/>
</list>
<list name="externalPackageFragmentRoots" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="ijavamodel_externalpackagefragmentroots">
<column name="`ijavamodel_externalpackagefragmentroots_e_id`" not-null="false" unique="false" index="IJavaModel_externalPackageFragmentRoots"/>
</key>
<list-index column="`ijavamodel_externalpackagefragmentroots_idx`"/>
<one-to-many entity-name="IPackageFragmentRoot"/>
</list>
</joined-subclass>
IJavaModel extends IJavaElement and PhysicalElement and is the model root's metaclass.
Thanks in advance.
| Re: [CDO] ClassCastException with CDO-Hibernate [message #730832 is a reply to message #730404] |
Thu, 29 September 2011 05:28  |
Martin Taal Messages: 5049 Registered: July 2009 |
I am on holiday/traveling, but hope to take a look later today.
gr. Martin
> Resource r = rs
> if (legacyMode) {
> try {
> session.close();
> System.exit(0);
> 'CDOResource')
> at
> at
> at
> at
> at
> </id>
> </property>
> </property>
> </property>
> </property>
> </class>
> </id>
> </property>
> </property>
> </property>
> </property>
> </property>
> </class>
> <key>
> </key>
> </key>
> </list>
> </key>
> </list>
> </joined-subclass>
> Thanks in advance.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Current Time: Tue May 21 06:07:02 EDT 2013
Powered by FUDForum. Page generated in 0.01700 seconds
