Home » Modeling » GMF (Graphical Modeling Framework) » Running GEF/GMF examples
Running GEF/GMF examples [message #730500] Wed, 28 September 2011 10:22 Go to next message
Neslepaks  is currently offline Neslepaks
Member
I am running Eclipse Indigo Modeling Tools and trying to get some GEF/GMF examples running. With a new workspace, I go to File -> New -> Example -> Geoshape (or WYSIWYG document or Flow). Then I try to run the plugin with "Launch Eclipse Application" and another instance of Eclipse opens but I cannot find any GUI-elements that seem relevant to these examples. I have succesfully run some other plugins.
How should I use these plugins?
Re: Running GEF/GMF examples [message #730526 is a reply to message #730500] Wed, 28 September 2011 10:26 Go to previous messageGo to next message
Mickael Istria is currently offline Mickael Istria
Maybe you should install GMF Tooling (which is not part of default
Eclipse Modeling distribution).
You can find it in this update-site:
http://download.eclipse.org/modeling/gmp/gmf-tooling/updates/dev-snapshots/
http://mickaelistria.wordpress.com
http://twitter.com/#!/mickaelistria
http://www.petalslink.com
Re: Running GEF/GMF examples [message #730795 is a reply to message #730526] Thu, 29 September 2011 03:47 Go to previous message
Member
Thanks, I am not sure if that was the solution but at least I got it working now. I needed to go trough the menu chain above and there were the new diagram/document types.
Previous Topic:How to realize the parameter of methods like in uml class diagram
Next Topic:PopUp window when a node is dragged and dropped on to the editor
Current Time: Thu May 23 09:37:46 EDT 2013
Powered by FUDForum. Page generated in 0.01958 seconds
