Home » Modeling » M2T (model-to-text transformation) » Modularizing an Acceleo transformation
Modularizing an Acceleo transformation [message #729927] Tue, 27 September 2011 05:45 Go to next message
My transformation is sufficiently large that I want to partition a
number of getXXX queries into separate modules so that they can be
invoked by a hierarchical name such as XXX::getA(), YYY::getB() etc,
rather than a lexical XXX_getA(), YYY_getB().
MOFM2T appears to support this through the use of PathNameCS in the
grammar but:
[module XXX::YYY ...
is not permitted by Acceleo. Reports that module must be defined in its
own file.
[import XXX::YYY
is not permitted by Acceleo. Reports that XXX::YYY cannot be found.
Surely XXX::YYY should be resolved relative to the transformation
module? Instead Acceleo seems to find any *.mtl file in the project
regardless of its folder path, which is a tenable implementation if
qualified names are supported on the module declaration, but it would
seem better to impose the constraint that file hierarchy and module
hierarchy align.i.e [module A::B::C ...] must be in .../A/B/C.mtl and
subsequent imports resolve with respect to .../, possibly extended by a
module path of additional roots.
XXX::YYY() invocation
of course fails with an unknown type since the module/import do not
support the declaration of the path scopes.
Is there any way to use hierarchical names in Acceleo?
Ed Willink
Re: Modularizing an Acceleo transformation [message #730024 is a reply to message #729927] Tue, 27 September 2011 10:09 Go to previous messageGo to next message
Stephane Begaudeau is currently offline Stephane Begaudeau
[import XXX::YYY
It is permitted and it is the recommended way(C. 8.) to realize an import. You can see an example here.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Google+: stephane.begaudeau
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
Re: Modularizing an Acceleo transformation [message #730085 is a reply to message #730024] Tue, 27 September 2011 11:22 Go to previous messageGo to next message
Hi Stephane
Thanks. It seems to work perfectly; just need to observe the reasonable
restriction of starting paths at the classpath root.
A properly qualified import just like Java is so much more professional
that perhaps you should make the unqualified form a warning. Perhaps an
error because without qualification, refactoring to rename one of a two
same-named pair of modules in independent plugins can have miraculous
side effects ignoring classpath visibilities.
It would be really good if the Acceleo documentation had a Language
Statements reference section that defined the above and described
Acceleo from the Concrete Syntax point of view. The MOFM2T spec
concentrates only on the Abstract Syntax.
Ed Willink
On 27/09/2011 15:09, Stephane Begaudeau wrote:
> [import XXX::YYY
> http://www.obeonetwork.com/page/acceleo-best-practices(C. 8.) to
> https://github.com/ObeoNetwork/UML-Java-Generation/blob/master/plugins/org.obeonetwork.pim.uml2.gen.java/src/org/obeonetwork/pim/uml2/gen/java/main/workflow.mtl.
> Twitter: http://twitter.com/#!/sbegaudeau
> Google+: http://www.google.com/profiles/stephane.begaudeau
Re: Modularizing an Acceleo transformation [message #730793 is a reply to message #730085] Thu, 29 September 2011 03:40 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent Goubet
Ed,
The unqualified form for imports is a legacy of the first versions of Acceleo 3... we kept it in when we added the qualified form in order not to break existing modules. However warning the users that this is not the recommended form is probably something we should do. Could you raise a bug to track this?
As for a "concrete syntax" reference for the Acceleo language, yes, that too would be interesting to have... as would an up-to-date, typo-free documentation in general :s.
Laurent Goubet
Obeo
Re: Modularizing an Acceleo transformation [message #730875 is a reply to message #730793] Thu, 29 September 2011 08:24 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=359411
On 29/09/2011 08:40, Laurent Goubet wrote:
> Ed,
> Laurent Goubet
> Obeo
Previous Topic:Out of Order text generation
Next Topic:[Acceleo 3.1] Metamodel loading issues
Current Time: Fri May 24 04:43:56 EDT 2013
Powered by FUDForum. Page generated in 0.01895 seconds
