Home » Eclipse Projects » Eclipse Communications Framework (ECF) » OSGi Remote DS product configuration works only inside Eclipse [SOLVED](the product exported through the configuration does not work outside eclipse)
| OSGi Remote DS product configuration works only inside Eclipse [SOLVED] [message #727722] |
Wed, 21 September 2011 17:29  |
Stefano Ghio Messages: 12 Registered: September 2011 |
Junior Member |
Greetings,
I'm working on Eclipse STS 2.7.2 with Java JDK 1.6, Windows XP SP3. I work behind a proxy which requires authentication.
I wrote two simple client and server plugins which work using DS and Zookeeper discovery. They refer to an IHello interface bundled in a third plugin.
The server publishes a simple Hello service which returns a string "hello" when invoked on 192.16.23.28:6666/hello and starts Zookeper with VM arguments -Dzoodiscovery.dataDir=bla
-Dzoodiscovery.flavor=zoodiscovery.flavor.standalone=192.168.23.28:3030;clientPort=3031
xml is:
<scr:component xmlns:scr="NOLINKALLOWED" name="it.eng.test.remote.ds.helloservice">
<implementation class="it.eng.test.remote.ds.helloservice.HelloService"/>
<property name="service.exported.interfaces" type="String" value="*"/>
<property name="service.exported.configs" type="String" value="ecf.generic.server"/>
<property name="ecf.exported.containerfactoryargs" type="String" value="ecftcp://192.168.23.28:6666/hello"/>
<service>
<provide interface="it.eng.test.remote.ds.hello.IHello"/>
</service>
</scr:component>
the client starts Zookeeper with VM arguments
-Dzoodiscovery.autoStart=true
-Dzoodiscovery.flavor=zoodiscovery.flavor.standalone=192.168.23.28:3031;clientPort=3030
In both cases the osgi framework is started with the -console -consoleLog -clean arguments.
I then created two separated run configuration for both server and client adding all required bundles (most important ones: org.eclipse.ecf.provider.remoteservice and org.eclipse.ecf.provider.zookeeper) and their dependencies.
Based on that configuration I defined two separated product configurations for both client and server.
Now, if I run them by clicking on the link "Launch an Eclipse application" inside the product configuration, everything works. The server publishes the service, the client gets it and shows "Hello" on output. netstat -a | grep 6666 shows that someone is listening on that port and netstat -a | grep 30 shows that port 3030 and 3031 are being used.
Eclipse is configured to use my proxy correctly.
If I export them as an Eclipse product based on the aforementioned configurations, I get two folders: client and server.
Inside them there's everything needed to run the applications inside an OSGi framework, including configuration files for both the framework and the VM. Starting the server works, I see someone listening on 6666 and zookeeper reports that the service has been published.
If I start the client, nothing happens. No output, no connections on 3030 and 3031, no errors. It simply does nothing.
Using localhost instead of my IP changes nothing, it works inside Eclipse but not outside.
Any suggestion?
Thank you
[Updated on: Mon, 26 September 2011 07:11] Report message to a moderator
| Re: OSGi Remote DS example not working [message #729449 is a reply to message #727722] |
Mon, 26 September 2011 04:19   |
Markus Kuppe Messages: 177 Registered: July 2009 |
On 09/21/2011 11:29 PM, Stefano Ghio wrote:
> Greetings,
> I have a problem trying to get to work the remote DS example from the
> guide EIG:Getting_Started_with_OSGi_Remote_Services. In particular I'm
> referring to: org.eclipse.ecf.examples.remoteservices.hello.host.ds,
> org.eclipse.ecf.examples.remoteservices.hello.consumer.ds and
> The problem occurs in Eclipse Helios, Eclipse Indigo and STS 2.6.2. All
> of them have the ECF remote services target components installed
> although not exactly as the guide says(refer to thread: A problem with
> install ECF 3.5.2 message 722064). It occurs on both Java1.6 and 1.7
> SDK, I even modified the MANIFEST properly to require one of those
> environments.
> I can compile the code with no problems but when I run (run as->OSGi
> framework, select all dependencies and nothing more and successfully
> validate the bundles prior to launching) nothing happens, the bundles
> are there, I can start/stop them but I see no output on the console.
> Moreover, if I netstat -a there are no services listening on the port
> 3787 specified in the OSGI-INF/hello.xml
> Plus, if I look at the services exported, none of the said bundles
> exports/uses the services it declares in its xml configuration, even
> looking at the bundle info it does not show any exported or reference
> services, only exported/required packages.
> Starting the bundles with the framework or later does not change a
> thing, I still see no output and no services exported.
> Sorry I didn't provide direct links but the system does not allow me to
> do so right now.
> Thanks for your help,
> cheers
Hi Stefano,
please post the list of bundles ("ss") and services ("services") on both
host and consumer side.
Markus
| Re: OSGi Remote DS example not working [message #729479 is a reply to message #729449] |
Mon, 26 September 2011 05:36   |
Junior Member |
it's going to be a long post.. I will post first what I get if I launch them from WITHIN Eclipse
here's server side bundles list (my bundles are 24, 26):
osgi> ss
Framework is launched.
id State Bundle
0 ACTIVE org.eclipse.osgi_3.7.0.v20110613
Fragments=2, 6, 20
1 <<LAZY>> org.eclipse.core.contenttype_3.4.100.v20110423-0524
2 RESOLVED org.eclipse.persistence.jpa.equinox.weaving_2.3.0.v20110604-r9504
Master=0
3 ACTIVE org.eclipse.core.jobs_3.5.100.v20110404
4 ACTIVE org.eclipse.equinox.preferences_3.4.0.v20110502
5 ACTIVE org.eclipse.equinox.util_1.0.300.v20110502
6 RESOLVED javax.transaction_1.1.1.v201105210645
Master=0
7 ACTIVE org.eclipse.osgi.services_3.3.0.v20110513
8 ACTIVE org.eclipse.ecf.identity_3.1.100.v20110531-2218
9 ACTIVE org.apache.log4j_1.2.15.v201012070815
10 ACTIVE org.eclipse.equinox.registry_3.5.100.v20110502
Fragments=22
11 ACTIVE org.eclipse.ecf.provider_4.2.0.v20110829-0349
12 ACTIVE org.eclipse.ecf.remoteservice_6.0.200.v20110829-0349
13 ACTIVE org.eclipse.ecf.sharedobject_2.2.100.v20110829-0349
14 RESOLVED org.eclipse.ecf.ssl_1.0.100.v20110531-2218
Master=21
15 ACTIVE org.eclipse.core.runtime_3.7.0.v20110110
16 ACTIVE org.eclipse.ecf.discovery_4.0.0.v20110829-0349
17 ACTIVE org.eclipse.equinox.ds_1.3.0.v20110502
18 ACTIVE org.eclipse.ecf.osgi.services.remoteserviceadmin_2.0.100.v20110829-0349
19 ACTIVE org.eclipse.ecf.osgi.services.remoteserviceadmin.proxy_1.0.0.v20110829-0349
20 RESOLVED org.eclipse.equinox.weaving.hook_1.0.100.HEAD
Master=0
21 ACTIVE org.eclipse.ecf_3.1.300.v20110531-2218
Fragments=14
22 RESOLVED org.eclipse.core.runtime.compatibility.registry_3.5.0.v20110505
Master=10
23 ACTIVE org.eclipse.equinox.common_3.6.0.v20110523
-> 24 RESOLVED it.eng.test.remote.ds.hello_1.0.0.qualifier
25 ACTIVE org.eclipse.osgi.services.remoteserviceadmin_1.0.0.v20110828-1633
-> 26 ACTIVE it.eng.test.remote.ds.helloservice_1.0.0.qualifier
27 ACTIVE org.eclipse.ecf.osgi.services.distribution_2.0.100.v20110829-0349
28 ACTIVE org.eclipse.equinox.app_1.3.100.v20110321
29 ACTIVE org.eclipse.ecf.provider.remoteservice_4.0.0.v20110829-0349
30 ACTIVE org.apache.hadoop.zookeeper_3.3.3.v201105210832
31 ACTIVE org.eclipse.ecf.provider.zookeeper_1.0.100.v20110829-0349
32 ACTIVE org.eclipse.equinox.concurrent_1.0.200.v20110502
and services:
osgi> services
{org.eclipse.osgi.framework.console.CommandProvider}={service.ranking=2147483647, service.id=2}
Registered by bundle: org.eclipse.osgi_3.7.0.v20110613 [0]
Bundles using service:
{org.osgi.service.packageadmin.PackageAdmin}={service.ranking=2147483647, service.pid=0.org.eclipse.osgi.framework.internal.core.PackageAdminImpl, service.vendor=Eclipse.org - Equinox, service.id=4}
org.eclipse.equinox.common_3.6.0.v20110523 [23]
org.eclipse.core.runtime_3.7.0.v20110110 [15]
org.eclipse.equinox.preferences_3.4.0.v20110502 [4]
org.eclipse.core.jobs_3.5.100.v20110404 [3]
org.eclipse.equinox.app_1.3.100.v20110321 [28]
org.eclipse.equinox.registry_3.5.100.v20110502 [10]
org.eclipse.ecf.osgi.services.distribution_2.0.100.v20110829-0349 [27]
{org.osgi.service.permissionadmin.PermissionAdmin, org.osgi.service.condpermadmin.ConditionalPermissionAdmin}={service.ranking=2147483647, service.pid=0.org.eclipse.osgi.internal.permadmin.SecurityAdmin, service.vendor=Eclipse.org - Equinox, service.id=5}
No bundles using service.
{org.osgi.service.startlevel.StartLevel}={service.ranking=2147483647, service.pid=0.org.eclipse.osgi.framework.internal.core.StartLevelManager, service.vendor=Eclipse.org - Equinox, service.id=6}
{org.eclipse.osgi.service.debug.DebugOptions}={service.ranking=2147483647, service.pid=0.org.eclipse.osgi.framework.debug.FrameworkDebugOptions, service.vendor=Eclipse.org - Equinox, service.id=7}
org.eclipse.ecf.identity_3.1.100.v20110531-2218 [8]
{java.lang.ClassLoader}={service.ranking=2147483647, service.pid=0.org.eclipse.core.runtime.internal.adaptor.ContextFinder, service.vendor=Eclipse.org - Equinox, equinox.classloader.type=contextClassLoader, service.id=8}
{org.eclipse.osgi.framework.log.FrameworkLog}={service.ranking=2147483647, service.pid=0.org.eclipse.core.runtime.internal.adaptor.EclipseLogFactory, service.vendor=Eclipse.org - Equinox, service.id=11}
org.eclipse.equinox.ds_1.3.0.v20110502 [17]
{org.eclipse.osgi.service.environment.EnvironmentInfo}={service.ranking=2147483647, service.pid=0.org.eclipse.core.runtime.internal.adaptor.EclipseEnvironmentInfo, service.vendor=Eclipse.org - Equinox, service.id=21}
{org.eclipse.osgi.service.resolver.PlatformAdmin}={service.ranking=2147483647, service.pid=0.org.eclipse.osgi.internal.baseadaptor.StateManager, service.vendor=Eclipse.org - Equinox, service.id=22}
{org.eclipse.osgi.service.pluginconversion.PluginConverter}={service.ranking=2147483647, service.pid=0.org.eclipse.core.runtime.internal.adaptor.PluginConverterImpl, service.vendor=Eclipse.org - Equinox, service.id=23}
{org.eclipse.osgi.framework.console.CommandProvider}={service.ranking=2147483647, service.pid=0.org.eclipse.core.runtime.internal.adaptor.EclipseCommandProvider, service.vendor=Eclipse.org - Equinox, service.id=24}
{org.eclipse.osgi.service.localization.BundleLocalization}={service.ranking=2147483647, service.pid=0.org.eclipse.core.runtime.internal.adaptor.BundleLocalizationImpl, service.vendor=Eclipse.org - Equinox, service.id=25}
{org.eclipse.osgi.framework.console.CommandProvider}={service.ranking=2147483647, service.id=31}
Registered by bundle: org.eclipse.equinox.ds_1.3.0.v20110502 [17]
{org.eclipse.osgi.framework.console.ConsoleSession}={console.systemInOut=true, service.id=3}
{org.osgi.service.log.LogReaderService, org.eclipse.equinox.log.ExtendedLogReaderService}={service.id=9}
{org.osgi.service.log.LogService, org.eclipse.equinox.log.ExtendedLogService}={service.id=10}
org.eclipse.ecf.provider.zookeeper_1.0.100.v20110829-0349 [31]
org.eclipse.ecf.osgi.services.remoteserviceadmin_2.0.100.v20110829-0349 [18]
{javax.xml.parsers.SAXParserFactory}={service.id=13}
{javax.xml.parsers.DocumentBuilderFactory}={service.id=14}
{org.eclipse.osgi.service.datalocation.Location}={type=osgi.user.area, service.id=15}
{org.eclipse.osgi.service.datalocation.Location}={type=osgi.instance.area, service.id=16}
{org.eclipse.osgi.service.datalocation.Location}={type=osgi.configuration.area, service.id=17}
{org.eclipse.osgi.service.datalocation.Location}={type=osgi.install.area, service.id=18}
{org.eclipse.osgi.service.datalocation.Location}={type=eclipse.home.location, service.id=19}
{org.eclipse.osgi.service.urlconversion.URLConverter}={protocol=[bundleentry,bundleresource], service.id=20}
{org.eclipse.osgi.signedcontent.SignedContentFactory}={service.id=27}
{org.eclipse.osgi.internal.provisional.verifier.CertificateVerifierFactory}={service.id=28}
{org.osgi.service.framework.CompositeBundleFactory}={service.id=29}
{org.osgi.service.cm.ConfigurationListener}={service.id=30}
{org.apache.felix.scr.ScrService}={service.id=32}
{org.eclipse.osgi.service.urlconversion.URLConverter}={protocol=platform, service.id=33}
Registered by bundle: org.eclipse.equinox.common_3.6.0.v20110523 [23]
{org.eclipse.core.runtime.IAdapterManager}={service.id=34}
org.eclipse.ecf.provider_4.2.0.v20110829-0349 [11]
org.eclipse.ecf.sharedobject_2.2.100.v20110829-0349 [13]
{org.osgi.service.url.URLStreamHandlerService}={url.handler.protocol=[platform], service.id=35}
{org.eclipse.equinox.internal.util.threadpool.ThreadPoolManager, org.eclipse.equinox.internal.util.threadpool.ThreadPoolFactory}={service.id=36}
Registered by bundle: org.eclipse.equinox.util_1.0.300.v20110502 [5]
{org.eclipse.equinox.internal.util.timer.Timer}={service.id=37}
{it.eng.test.remote.ds.hello.IHello}={ecf.exported.containerfactoryargs=ecftcp://localhost:6666/hello, component.name=it.eng.test.remote.ds.helloservice, component.id=0, service.exported.configs=ecf.generic.server, service.exported.interfaces=*, service.id=38}
Registered by bundle: it.eng.test.remote.ds.helloservice_1.0.0.qualifier [26]
{org.eclipse.core.internal.preferences.exchange.IProductPreferencesService}={service.id=39}
Registered by bundle: org.eclipse.core.runtime_3.7.0.v20110110 [15]
{org.eclipse.core.runtime.preferences.IPreferencesService}={service.id=40}
Registered by bundle: org.eclipse.equinox.preferences_3.4.0.v20110502 [4]
{org.osgi.service.prefs.PreferencesService}={service.id=41}
{org.eclipse.core.runtime.jobs.IJobManager}={service.id=42}
Registered by bundle: org.eclipse.core.jobs_3.5.100.v20110404 [3]
{org.eclipse.core.runtime.IExtensionRegistry}={service.id=43}
Registered by bundle: org.eclipse.equinox.registry_3.5.100.v20110502 [10]
org.eclipse.ecf_3.1.300.v20110531-2218 [21]
{org.eclipse.osgi.framework.console.CommandProvider}={service.id=44}
{org.osgi.service.application.ApplicationDescriptor}={eclipse.application.type=any.thread, application.name=, application.visible=true, application.container=org.eclipse.equinox.app, service.pid=it.eng.test.remote.ds.helloservice.HelloServiceTest, application.launchable=true, eclipse.application.default=true, application.locked=false, application.location=initial@reference:file:../../Documents and Settings/GHIO/eclipse_workspace/STS/rosgi_ds/it.eng.test.remote.ds.helloservice/, service.id=45}
Registered by bundle: org.eclipse.equinox.app_1.3.100.v20110321 [28]
{org.osgi.service.application.ApplicationDescriptor}={eclipse.application.type=main.thread, application.name=, application.visible=false, application.container=org.eclipse.equinox.app, service.pid=org.eclipse.equinox.app.error, application.launchable=false, application.locked=false, application.location=initial@reference:file:plugins/org.eclipse.equinox.app_1.3.100.v20110321.jar/, service.id=46}
{org.osgi.service.application.ApplicationHandle, org.eclipse.equinox.app.IApplicationContext}={application.state=org.eclipse.equinox.app.starting, eclipse.application.type=any.thread, application.supports.exitvalue=true, eclipse.application.default=true, service.pid=it.eng.test.remote.ds.helloservice.HelloServiceTest.0, application.descriptor=it.eng.test.remote.ds.helloservice.HelloServiceTest, service.id=47}
{org.eclipse.osgi.framework.console.CommandProvider}={service.id=48}
{org.eclipse.ecf.core.identity.IIDFactory}={service.id=49}
Registered by bundle: org.eclipse.ecf.identity_3.1.100.v20110531-2218 [8]
{org.osgi.service.remoteserviceadmin.RemoteServiceAdmin}={org.eclipse.ecf.rsa=true, service.id=50}
Registered by bundle: org.eclipse.ecf.osgi.services.remoteserviceadmin_2.0.100.v20110829-0349 [18]
{javax.net.ssl.SSLSocketFactory}={service.id=55}
Registered by bundle: org.eclipse.ecf_3.1.300.v20110531-2218 [21]
{org.eclipse.ecf.core.IContainerFactory}={service.id=56}
{org.eclipse.ecf.core.IContainerManager}={service.id=57}
{org.osgi.service.remoteserviceadmin.EndpointListener}={endpoint.listener.scope=(!(endpoint.framework.uuid=707a1f6d-1de8-0010-178e-c64a5bd97bb1)), service.id=58}
Registered by bundle: org.eclipse.ecf.osgi.services.distribution_2.0.100.v20110829-0349 [27]
{org.osgi.framework.hooks.service.EventHook}={service.id=59}
{org.eclipse.ecf.discovery.IDiscoveryLocator, org.eclipse.ecf.discovery.IDiscoveryAdvertiser}={org.eclipse.ecf.discovery.containerName=ecf.discovery.zoodiscovery, service.id=62}
Registered by bundle: org.eclipse.ecf.provider.zookeeper_1.0.100.v20110829-0349 [31]
{org.eclipse.osgi.service.runnable.StartupMonitor}={service.ranking=-2147483648, service.id=1}
{org.eclipse.osgi.framework.log.FrameworkLog}={service.ranking=-2147483648, performance=true, service.pid=46org.eclipse.core.runtime.internal.adaptor.EclipseLogFactory$1, service.vendor=Eclipse.org - Equinox, service.id=12}
{org.eclipse.osgi.service.security.TrustEngine}={service.ranking=-2147483648, osgi.signedcontent.trust.engine=org.eclipse.osgi, service.id=26}
{org.eclipse.ecf.osgi.services.remoteserviceadmin.IEndpointDescriptionAdvertiser}={service.ranking=-2147483648, service.id=51}
{org.eclipse.ecf.osgi.services.remoteserviceadmin.IServiceInfoFactory}={service.ranking=-2147483648, service.id=52}
{org.eclipse.ecf.osgi.services.remoteserviceadmin.IDiscoveredEndpointDescriptionFactory}={service.ranking=-2147483648, service.id=53}
{org.eclipse.ecf.osgi.services.remoteserviceadmin.IEndpointDescriptionReader}={service.ranking=-2147483648, service.id=54}
{org.eclipse.ecf.osgi.services.remoteserviceadmin.IHostContainerSelector}={service.ranking=-2147483648, service.id=60}
{org.eclipse.ecf.osgi.services.remoteserviceadmin.IConsumerContainerSelector}={service.ranking=-2147483648, service.id=61}
And here's the client side bundles (16,25):
osgi> ss
id State Bundle
Fragments=2, 6, 21
1 ACTIVE org.eclipse.core.contenttype_3.4.100.v20110423-0524
Master=0
3 ACTIVE org.eclipse.equinox.preferences_3.4.0.v20110502
4 ACTIVE org.eclipse.core.jobs_3.5.100.v20110404
Master=0
Fragments=24
Master=22
->16 ACTIVE it.eng.test.remote.ds.helloconsumer_1.0.0.qualifier
17 ACTIVE org.eclipse.ecf.discovery_4.0.0.v20110829-0349
18 ACTIVE org.eclipse.equinox.ds_1.3.0.v20110502
19 ACTIVE org.eclipse.ecf.osgi.services.remoteserviceadmin_2.0.100.v20110829-0349
20 ACTIVE org.eclipse.ecf.osgi.services.remoteserviceadmin.proxy_1.0.0.v20110829-0349
21 RESOLVED org.eclipse.equinox.weaving.hook_1.0.100.HEAD
Master=0
22 ACTIVE org.eclipse.ecf_3.1.300.v20110531-2218
Fragments=14
24 RESOLVED org.eclipse.core.runtime.compatibility.registry_3.5.0.v20110505
Master=10
->25 ACTIVE it.eng.test.remote.ds.hello_1.0.0.qualifier
26 ACTIVE org.eclipse.osgi.services.remoteserviceadmin_1.0.0.v20110828-1633
27 ACTIVE org.eclipse.equinox.app_1.3.100.v20110321
28 ACTIVE org.eclipse.ecf.osgi.services.distribution_2.0.100.v20110829-0349
31 ACTIVE org.eclipse.equinox.concurrent_1.0.200.v20110502
32 ACTIVE org.eclipse.ecf.provider.zookeeper_1.0.100.v20110829-0349
and the services:
osgi> services
org.eclipse.equinox.preferences_3.4.0.v20110502 [3]
org.eclipse.core.jobs_3.5.100.v20110404 [4]
org.eclipse.equinox.app_1.3.100.v20110321 [27]
org.eclipse.ecf.osgi.services.distribution_2.0.100.v20110829-0349 [28]
org.eclipse.core.contenttype_3.4.100.v20110423-0524 [1]
org.eclipse.equinox.ds_1.3.0.v20110502 [18]
Registered by bundle: org.eclipse.equinox.ds_1.3.0.v20110502 [18]
org.eclipse.ecf.provider.zookeeper_1.0.100.v20110829-0349 [32]
org.eclipse.ecf.osgi.services.remoteserviceadmin_2.0.100.v20110829-0349 [19]
{org.eclipse.core.runtime.IExtensionRegistry}={service.id=36}
org.eclipse.ecf_3.1.300.v20110531-2218 [22]
{org.eclipse.osgi.framework.console.CommandProvider}={service.id=37}
{org.eclipse.core.runtime.preferences.IPreferencesService}={service.id=38}
Registered by bundle: org.eclipse.equinox.preferences_3.4.0.v20110502 [3]
{org.osgi.service.prefs.PreferencesService}={service.id=39}
{org.eclipse.core.runtime.content.IContentTypeManager}={service.id=40}
Registered by bundle: org.eclipse.core.contenttype_3.4.100.v20110423-0524 [1]
{org.eclipse.core.runtime.jobs.IJobManager}={service.id=41}
Registered by bundle: org.eclipse.core.jobs_3.5.100.v20110404 [4]
{org.eclipse.equinox.internal.util.threadpool.ThreadPoolManager, org.eclipse.equinox.internal.util.threadpool.ThreadPoolFactory}={service.id=42}
{org.eclipse.equinox.internal.util.timer.Timer}={service.id=43}
{org.eclipse.ecf.core.identity.IIDFactory}={service.id=44}
{org.eclipse.core.internal.preferences.exchange.IProductPreferencesService}={service.id=45}
{org.osgi.service.application.ApplicationDescriptor}={eclipse.application.type=any.thread, application.name=, application.visible=true, application.container=org.eclipse.equinox.app, service.pid=it.eng.test.remote.ds.helloconsumer.HelloConsumerTest, application.launchable=true, application.locked=false, application.location=initial@reference:file:../../Documents and Settings/GHIO/eclipse_workspace/STS/rosgi_ds/it.eng.test.remote.ds.helloconsumer/, service.id=46}
Registered by bundle: org.eclipse.equinox.app_1.3.100.v20110321 [27]
{org.osgi.service.application.ApplicationDescriptor}={eclipse.application.type=main.thread, application.name=, application.visible=false, application.container=org.eclipse.equinox.app, service.pid=org.eclipse.equinox.app.error, application.launchable=true, application.locked=false, application.location=initial@reference:file:plugins/org.eclipse.equinox.app_1.3.100.v20110321.jar/, service.id=47}
{org.osgi.service.remoteserviceadmin.RemoteServiceAdmin}={org.eclipse.ecf.rsa=true, service.id=49}
Registered by bundle: org.eclipse.ecf.osgi.services.remoteserviceadmin_2.0.100.v20110829-0349 [19]
{javax.net.ssl.SSLSocketFactory}={service.id=54}
Registered by bundle: org.eclipse.ecf_3.1.300.v20110531-2218 [22]
{org.eclipse.ecf.core.IContainerFactory}={service.id=55}
{org.eclipse.ecf.core.IContainerManager}={service.id=56}
{org.osgi.service.remoteserviceadmin.EndpointListener}={endpoint.listener.scope=(!(endpoint.framework.uuid=d0877332-1ee8-0010-1884-8d5ba58e77a3)), service.id=57}
Registered by bundle: org.eclipse.ecf.osgi.services.distribution_2.0.100.v20110829-0349 [28]
{org.osgi.framework.hooks.service.EventHook}={service.id=58}
{org.eclipse.ecf.discovery.IDiscoveryLocator, org.eclipse.ecf.discovery.IDiscoveryAdvertiser}={org.eclipse.ecf.discovery.containerName=ecf.discovery.zoodiscovery, service.id=59}
Registered by bundle: org.eclipse.ecf.provider.zookeeper_1.0.100.v20110829-0349 [32]
{it.eng.test.remote.ds.hello.IHello}={ecf.service.imported.endpoint.service.id=1, service.imported=org.eclipse.ecf.provider.remoteservice.generic.RemoteServiceImpl@1455cf0, component.name=it.eng.test.remote.ds.helloservice, ecf.service.imported.endpoint.id=ecftcp://localhost:6666/hello, component.id=0, service.imported.configs=[ecf.generic.client], service.id=62}
Registered by bundle: org.eclipse.ecf.osgi.services.remoteserviceadmin.proxy_1.0.0.v20110829-0349 [20]
it.eng.test.remote.ds.helloconsumer_1.0.0.qualifier [16]
{org.eclipse.ecf.osgi.services.remoteserviceadmin.IEndpointDescriptionAdvertiser}={service.ranking=-2147483648, service.id=50}
{org.eclipse.ecf.osgi.services.remoteserviceadmin.IServiceInfoFactory}={service.ranking=-2147483648, service.id=51}
{org.eclipse.ecf.osgi.services.remoteserviceadmin.IDiscoveredEndpointDescriptionFactory}={service.ranking=-2147483648, service.id=52}
{org.eclipse.ecf.osgi.services.remoteserviceadmin.IEndpointDescriptionReader}={service.ranking=-2147483648, service.id=53}
Now, if I launch them OUTSIDE Eclipse:
Server bundles list:
id State Bundle
Fragments=3, 29, 32
->1 RESOLVED it.eng.test.remote.ds.hello_1.0.0.201109261051
->2 ACTIVE it.eng.test.remote.ds.helloservice_1.0.0.201109261051
3 RESOLVED javax.transaction_1.1.1.v201105210645
Master=0
4 ACTIVE org.apache.hadoop.zookeeper_3.3.3.v201105210832
5 ACTIVE org.apache.log4j_1.2.13.v200903072027
6 <<LAZY>> org.eclipse.core.contenttype_3.4.100.v20110423-0524
7 ACTIVE org.eclipse.core.jobs_3.5.100.v20110404
8 ACTIVE org.eclipse.core.runtime_3.7.0.v20110110
9 RESOLVED org.eclipse.core.runtime.compatibility.registry_3.5.0.v20110
505
Master=27
10 ACTIVE org.eclipse.ecf_3.1.300.v20110531-2218
Fragments=21
11 ACTIVE org.eclipse.ecf.discovery_4.0.0.v20110829-0349
12 ACTIVE org.eclipse.ecf.identity_3.1.100.v20110531-2218
13 ACTIVE org.eclipse.ecf.osgi.services.distribution_2.0.100.v20110829
-0349
14 ACTIVE org.eclipse.ecf.osgi.services.remoteserviceadmin_2.0.100.v20
110829-0349
15 ACTIVE org.eclipse.ecf.osgi.services.remoteserviceadmin.proxy_1.0.0
.v20110829-0349
16 ACTIVE org.eclipse.ecf.provider_4.2.0.v20110829-0349
17 ACTIVE org.eclipse.ecf.provider.remoteservice_4.0.0.v20110829-0349
18 ACTIVE org.eclipse.ecf.provider.zookeeper_1.0.100.v20110829-0349
19 ACTIVE org.eclipse.ecf.remoteservice_6.0.200.v20110829-0349
20 ACTIVE org.eclipse.ecf.sharedobject_2.2.100.v20110829-0349
21 RESOLVED org.eclipse.ecf.ssl_1.0.100.v20110531-2218
Master=10
22 ACTIVE org.eclipse.equinox.app_1.3.100.v20110321
24 ACTIVE org.eclipse.equinox.concurrent_1.0.200.v20110502
25 ACTIVE org.eclipse.equinox.ds_1.3.0.v20110502
26 ACTIVE org.eclipse.equinox.preferences_3.4.0.v20110502
27 ACTIVE org.eclipse.equinox.registry_3.5.100.v20110502
Fragments=9
28 ACTIVE org.eclipse.equinox.util_1.0.300.v20110502
29 RESOLVED org.eclipse.equinox.weaving.hook_1.0.100.HEAD
Master=0
30 ACTIVE org.eclipse.osgi.services_3.3.0.v20110513
31 ACTIVE org.eclipse.osgi.services.remoteserviceadmin_1.0.0.v20110828
-1633
32 RESOLVED org.eclipse.persistence.jpa.equinox.weaving_2.3.0.v20110604-
r9504
Master=0
Server services:
osgi> services
, service.id=2}
org.eclipse.core.runtime_3.7.0.v20110110 [8]
org.eclipse.equinox.preferences_3.4.0.v20110502 [26]
org.eclipse.core.jobs_3.5.100.v20110404 [7]
org.eclipse.equinox.app_1.3.100.v20110321 [22]
org.eclipse.equinox.registry_3.5.100.v20110502 [27]
org.eclipse.ecf.osgi.services.distribution_2.0.100.v20110829-0349 [13]
, service.id=5}
org.eclipse.ecf.identity_3.1.100.v20110531-2218 [12]
org.eclipse.equinox.ds_1.3.0.v20110502 [25]
, service.id=34}
Registered by bundle: org.eclipse.equinox.ds_1.3.0.v20110502 [25]
ervice.id=3}
ervice.id=10}
org.eclipse.ecf.provider.zookeeper_1.0.100.v20110829-0349 [18]
org.eclipse.ecf.osgi.services.remoteserviceadmin_2.0.100.v20110829-0349 [14]
d=15}
ce.id=16}
service.id=17}
e.id=18}
rvice.id=19}
vice.id=28}
e.id=30}
{org.eclipse.core.runtime.IAdapterManager}={service.id=31}
org.eclipse.ecf.provider_4.2.0.v20110829-0349 [16]
org.eclipse.ecf.sharedobject_2.2.100.v20110829-0349 [20]
service.id=32}
{org.osgi.service.cm.ConfigurationListener}={service.id=33}
{org.apache.felix.scr.ScrService}={service.id=35}
Registered by bundle: org.eclipse.equinox.util_1.0.300.v20110502 [28]
Registered by bundle: it.eng.test.remote.ds.helloservice_1.0.0.201109261051 [2
vice.id=39}
Registered by bundle: org.eclipse.core.runtime_3.7.0.v20110110 [8]
Registered by bundle: org.eclipse.equinox.preferences_3.4.0.v20110502 [26]
Registered by bundle: org.eclipse.core.jobs_3.5.100.v20110404 [7]
Registered by bundle: org.eclipse.equinox.registry_3.5.100.v20110502 [27]
org.eclipse.ecf_3.1.300.v20110531-2218 [10]
on.locked=false, application.location=initial@reference:file:plugins/it.eng.test
.remote.ds.helloservice_1.0.0.201109261051.jar/, service.id=45}
Registered by bundle: org.eclipse.equinox.app_1.3.100.v20110321 [22]
rvice.id=47}
{org.eclipse.osgi.service.runnable.ApplicationLauncher}={service.id=49}
{javax.net.ssl.SSLSocketFactory}={service.id=50}
Registered by bundle: org.eclipse.ecf_3.1.300.v20110531-2218 [10]
{org.eclipse.ecf.core.IContainerFactory}={service.id=51}
{org.eclipse.ecf.core.IContainerManager}={service.id=52}
{org.eclipse.ecf.core.identity.IIDFactory}={service.id=53}
Registered by bundle: org.eclipse.ecf.identity_3.1.100.v20110531-2218 [12]
ue, service.id=54}
(!(endpoint.framework.uuid=e00d3e21-1fe8-0010-1b7f-a91cc8cabc61)), service.id=59
0829-0349 [13]
{org.osgi.framework.hooks.service.EventHook}={service.id=60}
0829-0349 [13]
y, service.id=63}
9 [18]
service.id=1}
}={service.ranking=-2147483648, service.id=55}
ranking=-2147483648, service.id=56}
Factory}={service.ranking=-2147483648, service.id=57}
ervice.ranking=-2147483648, service.id=58}
0829-0349 [13]
ervice.ranking=-2147483648, service.id=62}
0829-0349 [13]
Client bundles (1,2):
id State Bundle
Fragments=3, 29, 32
->1 RESOLVED it.eng.test.remote.ds.hello_1.0.0.201109261120
->2 ACTIVE it.eng.test.remote.ds.helloconsumer_1.0.0.201109261120
Master=0
505
Master=27
Fragments=21
-0349
110829-0349
.v20110829-0349
Master=10
Fragments=9
Master=0
-1633
r9504
Master=0
Client services (in the next post):
[Updated on: Mon, 26 September 2011 05:52] Report message to a moderator
| Re: OSGi Remote DS example not working [message #729483 is a reply to message #729479] |
Mon, 26 September 2011 05:41   |
Junior Member |
Client services:
osgi> services
, service.id=2}
, service.id=5}
, service.id=34}
ervice.id=3}
ervice.id=10}
d=15}
ce.id=16}
service.id=17}
e.id=18}
rvice.id=19}
vice.id=28}
e.id=30}
service.id=32}
vice.id=38}
{org.eclipse.core.runtime.preferences.IPreferencesService}={service.id=39}
{org.osgi.service.prefs.PreferencesService}={service.id=40}
{org.eclipse.core.runtime.IExtensionRegistry}={service.id=42}
{org.eclipse.osgi.framework.console.CommandProvider}={service.id=43}
umerTest, application.launchable=true, eclipse.application.default=true, applica
tion.locked=false, application.location=initial@reference:file:plugins/it.eng.te
st.remote.ds.helloconsumer_1.0.0.201109261120.jar/, service.id=44}
ce:file:plugins/org.eclipse.equinox.app_1.3.100.v20110321.jar/, service.id=45}
.default=true, service.pid=it.eng.test.remote.ds.helloconsumer.HelloConsumerTest
.0, application.descriptor=it.eng.test.remote.ds.helloconsumer.HelloConsumerTest
, service.id=46}
{org.eclipse.osgi.framework.console.CommandProvider}={service.id=47}
{org.eclipse.osgi.service.runnable.ApplicationLauncher}={service.id=48}
{javax.net.ssl.SSLSocketFactory}={service.id=49}
{org.eclipse.ecf.core.IContainerFactory}={service.id=50}
{org.eclipse.ecf.core.IContainerManager}={service.id=51}
{org.eclipse.ecf.core.identity.IIDFactory}={service.id=52}
ue, service.id=53}
(!(endpoint.framework.uuid=c007ede1-20e8-0010-10d5-dd36fd36877a)), service.id=58
0829-0349 [13]
0829-0349 [13]
y, service.id=60}
9 [18]
service.id=1}
Factory}={service.ranking=-2147483648, service.id=56}
As you can see, the difference is that outside Eclipse the service is not discovered, yet it's active and advertised as I get this when I start the server:
osgi> ZooDiscovery> Discovery Service Activated. 26-set-2011 11.28.18.
log4j:WARN No appenders could be found for logger (org.apache.zookeeper.server.Z
ooKeeperServer).
log4j:WARN Please initialize the log4j system properly.
ZooDiscovery> Service Published: 26-set-2011 11.28.19. ServiceInfo[uri=ecf.osgir
svc://localhost:6666/osgirsvc_d4qursM8oeHV4qTY0b7Nq12NseI=;id=ServiceID[type=Ser
viceTypeID[typeName=_ecf.osgirsvc._default.default._iana];location=ecf.osgirsvc:
//localhost:6666/osgirsvc_d4qursM8oeHV4qTY0b7Nq12NseI=;full=_ecf.osgirsvc._defau
lt.default._iana@ecf.osgirsvc://localhost:6666/osgirsvc_d4qursM8oeHV4qTY0b7Nq12N
seI=];priority=0;weight=0;props=ServiceProperties[{endpoint.service.id=1, compon
ent.name=it.eng.test.remote.ds.helloservice, objectClass=it.eng.test.remote.ds.h
ello.IHello, endpoint.framework.uuid=902cf1dd-21e8-0010-1601-c115c69f3014, remot
e.intents.supported=passByValue exactlyOnce ordered, ecf.endpoint.id.ns=org.ecli
pse.ecf.core.identity.StringID, remote.configs.supported=ecf.generic.server, end
=ecf.generic.server}]]
C:\Documents and Settings\GHIO>netstat -a | grep 6666
TCP stefghiow:6666 stefghiow:0 LISTENING
And this when I start the client:
osgi> ZooDiscovery> Discovery Service Activated. 26-set-2011 11.29.41.
I attach the projects:
hello is the interface
helloservice is the server -> configuration: helloservicezookeeper.product
helloconsumer is the client -> configuration: helloconsumerzookeeper.product
cheers
ps: sorry it's a little unreadable but setting bold or changing colour didn't work and I couldn't highlight the relevant parts. I used -> and ->>>>>>>>>>>> to make them pop out
[Updated on: Mon, 26 September 2011 05:54] Report message to a moderator
Current Time: Thu May 23 09:30:19 EDT 2013
Powered by FUDForum. Page generated in 0.02269 seconds
