Home » Archived » M2M (model-to-model transformation) » [QVTO] Accessing Java class members from transformations
[QVTO] Accessing Java class members from transformations [message #727437] Wed, 21 September 2011 05:57 Go to next message
Jan  is currently offline Jan
Hi there,
I'm just wondering if it is possible to access attributes or even methods of arbitrary Java classes from within a transformation.
To be specific, I want to read some static String values that are needed for some model class attributes. I intend to avoid holding redundant information in the java and in the qvt world.
Any ideas?
Re: [QVTO] Accessing Java class members from transformations [message #727546 is a reply to message #727437] Wed, 21 September 2011 10:09 Go to previous messageGo to next message
Provide helper functions to provide access to the 'shared' data.
Ed Willink
On 21/09/2011 10:57, Jan wrote:
> Hi there,
> Any ideas?
Re: [QVTO] Accessing Java class members from transformations [message #727561 is a reply to message #727437] Wed, 21 September 2011 10:09 Go to previous messageGo to next message
Ed Willink
> Hi there,
> Any ideas?
Re: [QVTO] Accessing Java class members from transformations [message #727563 is a reply to message #727437] Wed, 21 September 2011 10:09 Go to previous messageGo to next message
Ed Willink
> Hi there,
> Any ideas?
Re: [QVTO] Accessing Java class members from transformations [message #728040 is a reply to message #727546] Thu, 22 September 2011 08:48 Go to previous messageGo to next message
I managed to build a seperate plugin with a Java class serving as a kind of library (org.eclipse.m2m.qvt.oml.javaBlackboxUnits extension point). However, when using the import statement in a qvto transformation file I cannot "run" this file (that is the transformation) via a run configuration. When I try to run it, it breaks up immediately without any error, trace file or other output. Running the transformation programmatically via java works just fine. Could this be a bug in the QVTO interpreter?
Re: [QVTO] Accessing Java class members from transformations [message #728153 is a reply to message #728040] Thu, 22 September 2011 12:03 Go to previous messageGo to next message
Hi Jan
Almost certainly a bg.
Have you looked in the Window->Show View->Error Log where many of the
more embarrassing error messages appear.
Ed Willink
Re: [QVTO] Accessing Java class members from transformations [message #728436 is a reply to message #728153] Fri, 23 September 2011 05:33 Go to previous message
I did, but there is no error. I also tried the following:
1. Starting my transformation plugin (not the lib) via run->eclipse application
2. Writing a very simple transformation that imports the lib but does not its operations
3. Running the transformation via run->transformation bla (Don't use the plugin at all though)
That worked. Thus, it might be that my development workspace is somehow screwed up but without errors it's hard to tell.
[Updated on: Fri, 23 September 2011 05:34]
Report message to a moderator
Previous Topic:[QVT] result of allSubobjects on sets
Next Topic:[ATL] MWE2 component
Current Time: Fri May 24 10:19:02 EDT 2013
Powered by FUDForum. Page generated in 0.01938 seconds
