Home » Eclipse Projects » Eclipse 4 » problem opening Application.e4xmi in e4 windows 64bit
problem opening Application.e4xmi in e4 windows 64bit [message #571185] Fri, 19 March 2010 15:14 Go to next message
Todd Wilson is currently offline Todd Wilson
I've installed 2 versions of e4 on my Vista 64 bit:
eclipse-e4-SDK-incubation-I20100318-2100-win32-x86_64
eclipse-e4-SDK-incubation-1.0M4-win32-x86_64
I've tried sample e4 projects and creating new e4 projects on both installations, but whenever I try to open the Application.e4xmi file using the e4 Workbench Designer it just opens with a blank white interface (doesn't look like the screenshots of other OSes with the gui layout stuff).
Is this a known issue or is there a newer plugin I need on 64 bit for it to behave like the screenshots from the mac and 32 bit versions I've seen?
Todd
Re: problem opening Application.e4xmi in e4 windows 64bit [message #571244 is a reply to message #571185] Fri, 19 March 2010 22:10 Go to previous messageGo to next message
Lars Vogel is currently offline Lars Vogel
try the reflective EMF editor or a text editor, as described also here:
http://www.vogella.de/articles/EclipseE4/article.html
Best regards, Lars
> layout stuff).
> Todd
Re: problem opening Application.e4xmi in e4 windows 64bit [message #571270 is a reply to message #571244] Fri, 19 March 2010 22:23 Go to previous messageGo to next message
Hi Lars,
Thanks for the feedback. I've tried both the Sample Reflective Ecore Model Editor and a text editor with no troubles. It's only the e4 Workbench Designer that's not working. I couldn't find a bug report or find any posts from anyone else experiencing this issue on Windows 64 bit, so I was curious whether it was just me or if there are others that can't use the Workbench Designer then I would report a bug on Bugzilla.
Todd
Re: problem opening Application.e4xmi in e4 windows 64bit [message #720998 is a reply to message #571270] Wed, 31 August 2011 12:24 Go to previous messageGo to next message
Christian Hanster is currently offline Christian Hanster
Hey Todd,
I have the same issue with my eclipse now. How have you solved the problem??
It is a little bit crazy because at first it works and now there is a problem (see the screenshot). I haven't changed the code and now I don't know the problem.
Christian
Re: problem opening Application.e4xmi in e4 windows 64bit [message #721000 is a reply to message #720998] Wed, 31 August 2011 12:27 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
What is your version of the Eclipse 4.x and the tooling? There was a bug
in when elements got deleted they haven't been removed from the
references and so the model was invalid.
Can you send me your e4xmi-File so that I can take a look locally?
Tom
Am 31.08.11 18:24, schrieb christian-hanster:
> Hey Todd,
> Thanks
> Christian
Re: problem opening Application.e4xmi in e4 windows 64bit [message #721011 is a reply to message #721000] Wed, 31 August 2011 12:56 Go to previous messageGo to next message
Thank you for the very fast response. I use eclipse 4.1 with e4 0.11. I have added the .e4xmi in the attachements.
The full exception is:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.eclipse.e4.ui.model.application.ui.basic.impl.PartSashContainerImpl@1ed5c93a (elementId: null, tags: null, contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (horizontal: true)' is not legal. (platform:/resource/de.kvg-gymnasium.mobi.manager/Application.e4xmi, -1, -1)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:315)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:397)
	at org.eclipse.e4.tools.emf.ui.common.XMIModelResource.<init>(XMIModelResource.java:67)
	at org.eclipse.e4.tools.emf.editor3x.XMIResourceFunction.compute(XMIResourceFunction.java:21)
	at org.eclipse.e4.core.internal.contexts.ValueComputation.get(ValueComputation.java:122)
	at org.eclipse.e4.core.internal.contexts.EclipseContext.internalGet(EclipseContext.java:247)
	at org.eclipse.e4.core.internal.contexts.EclipseContext.internalGet(EclipseContext.java:255)
	at org.eclipse.e4.core.internal.contexts.EclipseContext.get(EclipseContext.java:208)
	at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier.fillArgs(ContextObjectSupplier.java:181)
	at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier.get(ContextObjectSupplier.java:165)
	at org.eclipse.e4.core.internal.di.InjectorImpl.resolveArgs(InjectorImpl.java:411)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:303)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:237)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:153)
	at org.eclipse.e4.tools.compat.internal.PartHelper.creatComponent(PartHelper.java:76)
	at org.eclipse.e4.tools.compat.parts.DIEditorPart.createPartControl(DIEditorPart.java:92)
	at org.eclipse.e4.tools.emf.editor3x.E4WorkbenchModelEditor.createPartControl(E4WorkbenchModelEditor.java:43)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:122)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:45)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:256)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:828)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:808)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:108)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:310)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:90)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:64)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:858)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:612)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:714)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:685)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:679)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:664)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:686)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:66)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4610)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:182)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:380)
	at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:357)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:311)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:273)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:912)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2729)
	at org.eclipse.ui.internal.WorkbenchPage.access$19(WorkbenchPage.java:2654)
	at org.eclipse.ui.internal.WorkbenchPage$7.run(WorkbenchPage.java:2636)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2632)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2612)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2603)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
	at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:355)
	at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:164)
	at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:249)
	at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:228)
	at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:275)
	at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:251)
	at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExplorerActionGroup.java:376)
	at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$4.open(PackageExplorerPart.java:538)
	at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
	at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
	at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
	at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
	at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
	at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
	at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
	at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4125)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1457)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1480)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1465)
	at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1270)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3971)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3610)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:969)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:885)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:87)
	at org.eclipse.ui.internal.Workbench$3.run(Workbench.java:539)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:519)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.eclipse.e4.ui.model.application.ui.basic.impl.PartSashContainerImpl@1ed5c93a (elementId: null, tags: null, contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (horizontal: true)' is not legal. (platform:/resource/de.kvg-gymnasium.mobi.manager/Application.e4xmi, -1, -1)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2663)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardReferences(XMLHandler.java:1149)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.endDocument(XMLHandler.java:1228)
	at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endDocument(AbstractSAXParser.java:737)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:516)
	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:808)
	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:737)
	at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:119)
	at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1205)
	at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:522)
	at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
	at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:181)
	at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:242)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1511)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1290)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:255)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:270)
	... 126 more
Caused by: java.lang.IllegalArgumentException: The selected element org.eclipse.e4.ui.model.application.ui.basic.impl.PartSashContainerImpl@1ed5c93a (elementId: null, tags: null, contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (horizontal: true) is not a child of this container
	at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:158)
	at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.eSet(ElementContainerImpl.java:234)
	at org.eclipse.e4.ui.model.application.ui.basic.impl.WindowImpl.eSet(WindowImpl.java:749)
	at org.eclipse.e4.ui.model.application.ui.basic.impl.TrimmedWindowImpl.eSet(TrimmedWindowImpl.java:121)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1081)
	at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHelperImpl.java:1210)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2658)
	... 142 more
I hope you can help me thank you.
Chrisitan
[Updated on: Wed, 31 August 2011 16:12]
Report message to a moderator
Re: problem opening Application.e4xmi in e4 windows 64bit [message #721100 is a reply to message #721011] Wed, 31 August 2011 17:18 Go to previous messageGo to next message
The problem is the selectedElement in your Window which is pointing to a
PartSashContainer which is kind of strange and I can't think how you
could get your model in this state.
if you change the XMI-File to make the TrimmedWindow look like this
> <children xsi:type="basic:TrimmedWindow" xmi:id="_BL6281IlEeC4t7DZ8Z1yaw" elementId="de.kvg-gymnasium.mobi.manager.MainWindow" label="Mobi-Manager" width="750" height="400">
It once more works.
Tom
Am 31.08.11 18:56, schrieb christian-hanster:
> Chrisitan
Re: problem opening Application.e4xmi in e4 windows 64bit [message #721106 is a reply to message #721100] Wed, 31 August 2011 17:53 Go to previous messageGo to next message
Thank you very much for the solution you have helped me very much also with your tutorial.
I first didn't have a perspectiveStack only the PartSash, then I added the perspective stack and put the partsash in the perspective and then eclipse does not recognize that PartSash can not be the selected element.
Christian
[Updated on: Wed, 31 August 2011 17:53]
Re: problem opening Application.e4xmi in e4 windows 64bit [message #721131 is a reply to message #721106] Wed, 31 August 2011 19:07 Go to previous messageGo to next message
That's what I thought also so i tried to reproduce it but was not able
to do so. Did you do this directly in the XMI or using the UI can you
give me detailed steps on how reproduce this because I tried and didn't
managed to do so.
Tom
Am 31.08.11 23:53, schrieb christian-hanster:
> with your tutorial. I first didn't have a perspectiveStack only the
> Christian
Re: problem opening Application.e4xmi in e4 windows 64bit [message #727218 is a reply to message #721131] Tue, 20 September 2011 12:15 Go to previous messageGo to next message
Sorry for the late response but I unsubscribed by mistake from this topic Sad
I have built the application with the "e4 workbenchmodel-editor". The problem is that I also have tried to reproduce the problem but I didn't get it.
I have the suspicion that my mac rans out of ram (I had only 2GB) and then eclipse does not have done all stuff with the xmi. In this time I had often problems with my mac slowing down because of not having enough memory.
Christian
Re: problem opening Application.e4xmi in e4 windows 64bit [message #728373 is a reply to message #727218] Fri, 23 September 2011 02:56 Go to previous messageGo to next message
Parvez Ahmad Hakim is currently offline Parvez Ahmad Hakim
Member
I get bellow error while running exported product file.
Can you help me. I tried bot features as well as plugin based approach, but no luck
Parvez Ahmad Hakim
Srinagar Kashmir http://www.abobjects.com
!SESSION 2011-09-23 11:07:40.531 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_11
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.equinox.app 0 0 2011-09-23 11:07:50.609
!MESSAGE Product org.cord.client.dms.mainapp.e4.product could not be found.
!ENTRY org.eclipse.osgi 4 0 2011-09-23 11:07:50.625
!MESSAGE Application error
!STACK 1
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:126)
Re: problem opening Application.e4xmi in e4 windows 64bit [message #728384 is a reply to message #728373] Fri, 23 September 2011 03:16 Go to previous message
Like stated in the error message the product can't be found. I guess the
reason is that the plugin.xml is missing in the build.properties.
There's been a bug in the project-wizard which didn't included necessary
files in the build.properties [1]
Tom
[1]https://bugs.eclipse.org/bugs/show_bug.cgi?id=351421
Am 23.09.11 08:56, schrieb Parvez Ahmad Hakim:
> but no luck
> Parvez Ahmad Hakim
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 1
> java.lang.NullPointerException
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
Previous Topic:E4 Eclipse product export wizard
Next Topic:Eclipse E4 - Example for css styling
Current Time: Tue May 21 18:15:40 EDT 2013
Powered by FUDForum. Page generated in 0.07991 seconds
