Home » Eclipse Projects » Virgo » Searching help: Virgo as maven dependencies(Trying to plug virgo on equinox )
Searching help: Virgo as maven dependencies [message #728123] Thu, 22 September 2011 11:04 Go to next message
Charlie Mordant is currently offline Charlie Mordant
Member
Hi all,
I'm trying to make a maven osgi simple project based on pax, gemini, equinox, virgo, blueprint and jsf.
I'm not an expert, but i've begun the project.
I'm locked for now with some errors on plugin-in Virgo on equinox via Maven..
Can someone try to look at this?
Thanks in advance, Tcharly (cmordant1@gmail.com for more infos).
Re: Searching help: Virgo as maven dependencies [message #728126 is a reply to message #728123] Thu, 22 September 2011 11:09 Go to previous messageGo to next message
Member
The project is easy to run: download pax script and put it on your path http://repo1.maven.org/maven2/org/ops4j/pax/construct/scripts/1.5/scripts-1.5.zip. Then run mvn install and pax-provision on the project root.
Happy debugging Wink
Re: Searching help: Virgo as maven dependencies [message #728254 is a reply to message #728126] Thu, 22 September 2011 15:39 Go to previous message
Dmitry Sklyut is currently offline Dmitry Sklyut
Virgo 3.x does not yet support Blueprint. I will try to look this over later today.
Dmitry
Previous Topic:spring osgi web bundle deployment exception
Next Topic:snaps grandkids
Current Time: Fri May 24 00:54:46 EDT 2013
Powered by FUDForum. Page generated in 0.01841 seconds
