Home » Language IDEs » AJDT » cast thisJoinPoint to ProceedingJoinPoint
cast thisJoinPoint to ProceedingJoinPoint [message #72724] Mon, 17 November 2008 08:04 Go to next message
Hao Missing name is currently offline Hao Missing name
I would like to write a function such that several round advices can call.
Inside the function proceed() method needs to be called. Can I cast
thisJoinPoint to ProceedingJoinPoint and pass it to the function within
round advice?
thanks
Re: cast thisJoinPoint to ProceedingJoinPoint [message #72750 is a reply to message #72724] Tue, 18 November 2008 03:44 Go to previous messageGo to next message
Eclipse User
Originally posted by: erdal.karaca.airbus.com
Even if you cast to ProceedingJoinPoint, this will not work (at least not
in ajdt 1.5).
My workaround for this:
void around(): ... {
Runnable proceed = new Runnable() {
public void run() {
proceed();
myFunction( proceed );
void myFunction( Runnable proceedingJoinPoint ) {
proceed.run();
I analysed this a while ago and I came to the conclusion that there were
something unbound (maybe a bug), such that
ProceedingJoinPoint.proceed(...) will fail when just cast from a
JoinPoint...
Re: cast thisJoinPoint to ProceedingJoinPoint [message #72796 is a reply to message #72750] Tue, 18 November 2008 17:15 Go to previous message
That's an acceptable approach.
thanks!
hao
Re: cast thisJoinPoint to ProceedingJoinPoint [message #599375 is a reply to message #72724] Tue, 18 November 2008 03:44 Go to previous message
Erdal Karaca is currently offline Erdal Karaca
in ajdt 1.5).
public void run() {
proceed();
proceed.run();
JoinPoint...
Re: cast thisJoinPoint to ProceedingJoinPoint [message #599438 is a reply to message #72750] Tue, 18 November 2008 17:15 Go to previous message
thanks!
hao
Previous Topic:What arguments should be passed to ProceedingJoinPoint
Next Topic:using Ajeer for RCP based on eclipse 3.2.3
Current Time: Sat May 18 10:00:58 EDT 2013
Powered by FUDForum. Page generated in 0.01920 seconds
