| Random errors in resolve step [message #555089] |
Wed, 25 August 2010 08:24  |
Peter Kullmann Messages: 188 Registered: July 2009 |
Sometimes I'm getting these errors when resolving a cquery.
The first possibility is this (see below for more context):
ERROR [0039] : java.lang.IllegalStateException: Preference node
" file:_home_svw_.hudson_jobs_ch.arenae.funtrade.client.rcp_wo rkspace_none "
has been removed.
The second one is this:
ERROR [0017] : java.lang.ArrayIndexOutOfBoundsException: -1
ERROR [0016] : java.lang.ArrayIndexOutOfBoundsException: -1
Both errors were generated by the resolver for the same cquery. I have
seen these errors on our hudson (headless buckminster) and also in the
ide. In the ide I usually just repeat the resolve action and then it
works ok.
Peter
Here is the complete log of the first kind of error:
INFO: resolve 'ch.arenae.funtrade.client.rcp.site.feature/target.cquery'
WARNING [0007] : Component request
org.junit.source:osgi.bundle/[3.8.2.v20090203-1005,3.8.2.v20 090203-1005]
is inconflict with request
org.junit.source:osgi.bundle/[4.8.1.v4_8_1_v20100114-1600,4. 8.1.v4_8_1_v20100114-1600]
org.junit:osgi.bundle/[3.8.2.v20090203-1005,3.8.2.v20090203- 1005] is
org.junit:osgi.bundle/[4.8.1.v4_8_1_v20100114-1600,4.8.1.v4_ 8_1_v20100114-1600]
inconflict with request org.junit:osgi.bundle/4.8.1
has been removed.
INFO: TAG-ID 0007 = Query for
ch.arenae.funtrade.client.rcp.target.feature:eclipse.feature , path:
ch.arenae.funtrade.client.rcp.target.feature:eclipse.feature $1.0.0.qualifier
-> org.junit.feature:eclipse.feature$3.8.2.201005141703
TAG-ID 0039 = Query for
org.eclipse.platform:eclipse.feature$3.6.0.v20100602-9gF78Gp qFt6trOGhL60z0oEx3fz-JKNwxPY
-> org.eclipse.rcp:eclipse.feature$3.6.0.v20100519-9OArFKvFtsd7 WLUKh-DcYTS
Here the log of the second kind:
-> org.jmock.feature:eclipse.feature$2.5.1.201005190853
TAG-ID 0016 = Query for
-> javax.xml.rpc:osgi.bundle$1.1.0.v201005080400 ->
org.apache.xerces:osgi.bundle$2.9.0.v200909240008
TAG-ID 0017 = Query for
-> ch.arenae.dnp.data.feature:eclipse.feature$2.0.0.N20100823-3 ->
org.apache.axis:osgi.bundle$1.4.0.201005181359
| Re: Random errors in resolve step [message #726666 is a reply to message #725908] |
Mon, 19 September 2011 04:18  |
Thorsten Meinl Messages: 83 Registered: July 2009 |
Member |
I found the cause: Since resolution during import is done concurrently
in different threads and my three repository placeholders referred to
the same non-existing location one thread removed the repository from a
list while another was just trying to access it. This problem should
really only happen, if one repository is referenced multiple times in an
RMap and it's non-existing. Thus in my case setting the three
placeholder variables to three different locations should fix it.
Am 16.09.2011 08:52, schrieb Thorsten Meinl:
> Hi all,
> I'm also experiencing similar problems since a few days. During
> resolution I sometimes (not everytime!) get
> ERROR [0064] : java.lang.IllegalStateException: Preference node
> "file:_dev_null" has been removed.
> or
> ERROR [0002] : java.lang.ArrayIndexOutOfBoundsException: -1
> Unfortunately without any further output on the console or in log files.
> I know what caused the problem, but I have no idea why.
> What I changed during the last days is that the properties file used
> during the import command (via -P) has three additional properties
> knime.repos.1=file:/dev/null
> knime.repos.2=file:/dev/null
> knime.repos.3=file:/dev/null
> These properties are referenced in the ressource map in a p2-reader, and
> some of them are dynamically set to the locations of p2 repositories
> created in a previous build step (I'm using Jenkins).
> If I have time, I will try to debug the issue but maybe someone has a
> hint or even an idea what is going wrong.
> Cheers,
> Thorsten
> Am 28.08.2010 13:34, schrieb Peter Kullmann:
>> Now, I was getting this one in the IDE:
>> Errors and Warnings
>> E [0181] : java.lang.ArrayIndexOutOfBoundsException: -1: -1
>> E [0179] : java.lang.ArrayIndexOutOfBoundsException:
>> Turning on Debug log level didn't help. No more information was
>> provided. After the third attempt it resolved ok.
>> Any idea?
>> Regards,
>> Peter
FUDForum. Page generated in 0.01723 seconds
