Home » Eclipse Projects » BIRT » Rendering the rptDocument while its being generated
Rendering the rptDocument while its being generated [message #725125] Tue, 13 September 2011 23:17 Go to next message
sam va is currently offline sam va
I have a requirement, where I need to render the rptDocument while its being generated.
Lets assume the rptDocument contains 40 pages and it has generated 2 pages and the rest are being processed. Can I use the same rptDocument to render the first page in HTML (using the report tag)?
[Updated on: Tue, 13 September 2011 23:20]
Report message to a moderator
Re: Rendering the rptDocument while its being generated [message #725141 is a reply to message #725125] Wed, 14 September 2011 00:58 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
When the report document is being created you can set a callback class
that you could use to do this. You set the page handler on the task like
task.setPageHandler( classinstance )
The class needs to implement the IPageHandler interface.
There may be an example of this in the
org.eclipse.birt.report.tests.engine.api project.
Jason
On 9/13/2011 11:17 PM, sam wrote:
> Hi
> being generated.
> to render the first page initially?
> Thanks
Jason Weathersby
BIRT Exchange
Re: Rendering the rptDocument while its being generated [message #725153 is a reply to message #725141] Wed, 14 September 2011 01:53 Go to previous messageGo to next message
thank you
Re: Rendering the rptDocument while its being generated [message #725750 is a reply to message #725153] Thu, 15 September 2011 12:37 Go to previous messageGo to next message
yes we can get the notifications.
But wouldn't using the same rptdocument, that is getting generated, to render create a problem. I am using run task to generate the document and report tag to render the document.
Re: Rendering the rptDocument while its being generated [message #726120 is a reply to message #725750] Fri, 16 September 2011 11:44 Go to previous message
I am not certain it will work with the report tag, but reading the
rptdocument as it is being created should be fine (guess).
Jason
> Thanks
Jason Weathersby
BIRT Exchange
Previous Topic:Wierd issue with Birt 3.7.0
Next Topic:Custom Emitter
Current Time: Wed May 22 06:04:19 EDT 2013
Powered by FUDForum. Page generated in 0.01627 seconds
