| Re: Multiple PictogramElements for single BusinessElement [message #726066 is a reply to message #726050] |
Fri, 16 September 2011 09:49  |
Matthias Gorning Messages: 80 Registered: April 2010 Location: Germany |
Member |
They will be selectable if your main PE's for StartNode, Connection and EndNode are all set to active.
Yes, it is possible to add a PE without having a BO.
If you have PE's linked with the same BO, or PE's without a BO you must be able to differentiate your PE's in your feature provider. You can simply do this, by adding properties to such kind of PE's.
FUDForum. Page generated in 0.04159 seconds
