Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EEF] use custom editor
[EEF] use custom editor [message #724810] Tue, 13 September 2011 04:46 Go to next message
Sébastien  Gandon is currently offline Sébastien Gandon
is there any documentation on how to use a custom editor with EEF.
Shall we create some template for generating specific editor's code or is it possible just to refer to some external widget classes from the EEF model?
Thanks for any input.
SeB.
Re: [EEF] use custom editor [message #724980 is a reply to message #724810] Tue, 13 September 2011 12:24 Go to previous messageGo to next message
Eclipse User
Originally posted by:
hi,
could you be more precise on your needs ?
if you are talking about the tree/masterpage form editor, please look at
goulwen's blog, especially
http://eef-modeling.blogspot.com/2011/01/eef-09-new-cool-feature-part-i-eef.html
Le 13/09/2011 10:46, S a écrit :
> Hello,
> EEF model?
> SeB.
Stéphane Bouchet, OBEO
Re: [EEF] use custom editor [message #725642 is a reply to message #724980] Thu, 15 September 2011 08:08 Go to previous messageGo to next message
Let's say I have my own combo box implementation that display icons in the combo and in the drop box (what swt does not provide).
How can I use this combo in the property sheet editor generated by EEF to edit one of my EMF feature ?
Re: [EEF] use custom editor [message #725971 is a reply to message #725642] Fri, 16 September 2011 05:48 Go to previous messageGo to next message
Stephane Bouchet is currently offline Stephane Bouchet
i responded to similar question some days ago :
http://www.eclipse.org/forums/index.php/mv/msg/238732/724976/#msg_724976
you can overrides the generated EEF code or overrides/create your own
acceleo templates, using your own widget element.
Le 15/09/2011 14:08, S a écrit :
Re: [EEF] use custom editor [message #725974 is a reply to message #725971] Fri, 16 September 2011 06:13 Go to previous message
Thank Stéphane,
I think this should be documented somehow.
Previous Topic:Where to download emf compare 1.1.2 ?
Next Topic:[JS4EMF] Embedding JS4EMF
Current Time: Sun May 26 01:39:11 EDT 2013
Powered by FUDForum. Page generated in 0.01845 seconds
