Home » Eclipse Projects » EGit » Possible to unstage/reset a single file?
Possible to unstage/reset a single file? [message #652757] Sun, 06 February 2011 07:10 Go to next message
h1055071 is currently offline h1055071
I'm getting to know eGit and git a whole lot better. It's looking good.
Is it possible to unstage/reset a single file? I know I can do a reset
for all staged files, but I'd like to do a single file, the equivalent of:
git reset HEAD newfile.java
Re: Possible to unstage/reset a single file? [message #652941 is a reply to message #652757] Mon, 07 February 2011 12:12 Go to previous messageGo to next message
Chris Aniszczyk is currently offline Chris Aniszczyk
File->Replace With->...
For resetting a current file... you'll have to wait until 0.12... it's going through the review process now...
http://egit.eclipse.org/r/#change,2415
Re: Possible to unstage/reset a single file? [message #653168 is a reply to message #652941] Tue, 08 February 2011 12:41 Go to previous messageGo to next message
Thanks, Chris.
Re: Possible to unstage/reset a single file? [message #653324 is a reply to message #652757] Wed, 09 February 2011 06:42 Go to previous messageGo to next message
Robin Rosenberg is currently offline Robin Rosenberg
On 2011-02-06 13.10, Phillipus wrote:
> Thanks
If you Enable quick diff you can select all text, right click in the
quickdiff bar to the left of the source code and select Revert
Selection. It reverts to the quickdiff baseline, which is by default HEAD.
-- robin
Re: Possible to unstage/reset a single file? [message #653370 is a reply to message #653324] Wed, 09 February 2011 09:45 Go to previous messageGo to next message
>> Thanks
> -- robin
What I'm trying to do is not roll back the local changes to the file but
to "unstage" ("un-Add") it from the index. I can do this in smartgit,
just wondering if it's something planned for eGit.
Phil
Re: Possible to unstage/reset a single file? [message #725182 is a reply to message #653370] Wed, 14 September 2011 03:23 Go to previous messageGo to next message
troys2005 is currently offline troys2005
Try using the mouse and dragging the file from the Staged Changes to Unstaged Changes. It seems to work. Let me know if this is what you were trying to do.
It would good to have a Stage/Unstage button in the Git Staging view. At least an Unstage since you can use Add for the initial Stage. Smile
Re: Possible to unstage/reset a single file? [message #725456 is a reply to message #725182] Wed, 14 September 2011 16:41 Go to previous message
R Shapiro is currently offline R Shapiro
In addition to drag-and-drop in the Git Staging view, you can also unstage changes with drag-and-drop in the Synchronization view. But I always use the Git Staging view, since Synchronization is too slow for my projects.
Previous Topic:Symbolic links in Linux
Next Topic:EGit wont push - Hook Declined
Current Time: Sun May 19 18:15:44 EDT 2013
Powered by FUDForum. Page generated in 0.01806 seconds
