Home » Eclipse Projects » BIRT » Chart engine: load XML file
Chart engine: load XML file [message #725359] Wed, 14 September 2011 11:14 Go to next message
Missing name Missing name is currently offline Missing name Missing name
Member
I'm using chart engine to generate Gantt diagram. The first step uses fake data. It's OK.
Now, I would like to load data from an XML file (generated by an EMF generated editor).
Before loading data, I often see in examples that the Design Engine is used. Why ? an rptdesign is it necessary ?
Then, I don't find example to load data from an XML file. Where can I find it ?
Thanks in advance.
Val
Re: Chart engine: load XML file [message #725390 is a reply to message #725359] Wed, 14 September 2011 12:14 Go to previous message
Jason Weathersby is currently offline Jason Weathersby
Val,
The Design Engine is not needed, but putting the chart in a report
design allows you to use the birt data sources. In your case you
probably should use an xml parser to get the values from the xml and use
these in your chart.
Jason
On 9/14/2011 11:14 AM, val.dupin wrote:
> Hello,
> fake data. It's OK.
> generated editor).
> find it ?
> Thanks in advance.
> Val
Jason Weathersby
BIRT Exchange
Previous Topic:Gantt chart: cannot have several entries in a serie
Next Topic:connecting to kdb
Current Time: Sun May 19 04:04:32 EDT 2013
Powered by FUDForum. Page generated in 0.05408 seconds
