Home » Eclipse Projects » Sapphire » Various Target Platforms
Various Target Platforms [message #725127] Wed, 14 September 2011 00:01 Go to next message
Kamesh Sampath is currently offline Kamesh Sampath
I have very fundamental question,
What is the purpose of various target platforms ?
1. dev-target
2. target-helios
3. target-juno42
Can we use #2 and #3 if we use eclipse installations helios or juno-42 ?
~Kamesh
Re: Various Target Platforms [message #725236 is a reply to message #725127] Wed, 14 September 2011 06:39 Go to previous messageGo to next message
Konstantin Komissarchik is currently offline Konstantin Komissarchik
Here are some properties of dev-target install as distinct from target-* installs:
1. It contains source code for all the plugins.
2. It contains Sapphire plugins. This makes it possible to only load the plugins you want to work on into your workspace.
3. It will only be touched by commandline build if you invoke create-dev-target or another target that includes it (like quick-start). This makes it possible to leave your workspace open for many commandline build operations.
I do use target-* installs in a pinch, like when the command-line build is failing as the build will not get far enough to create dev-target in this situation (needs to finish building Sapphire).
- Konstantin
Re: Various Target Platforms [message #725262 is a reply to message #725236] Wed, 14 September 2011 07:29 Go to previous messageGo to next message
> installs:
> build operations.
> - Konstantin
So if the dev-target is created properly during "ant clean-start" then
ideal target platfrom to use will be "dev-target" for all our Local
Sapphire build and development. Right ?
Re: Various Target Platforms [message #725287 is a reply to message #725262] Wed, 14 September 2011 08:49 Go to previous message
That is correct.
Previous Topic:Build Error
Next Topic:Sapphire - Juno-42 - Issues
Current Time: Tue May 21 13:44:11 EDT 2013
Powered by FUDForum. Page generated in 0.01671 seconds
