| Problem with radio button commands [message #724741] |
Mon, 12 September 2011 23:40 |
Srirekha P K Messages: 1 Registered: July 2011 |
Junior Member |
I am trying to place radio button commands in a popup menu within a view using the command framework. When I implemented the same I got some problems. The problem is that the radio button is not getting displayed when I select a menu item. But the popup menus are displayed and the states are changing according to the selection. The same commands are working with menus very well. Here's the portion of code in plugin.xml :
<extension
point="org.eclipse.ui.commands">
<command
defaultHandler="Radiosample"
id="commandframework.command1"
name="radiotest">
<commandParameter
id="org.eclipse.ui.commands.radioStateParameter1"
name="State"
optional="false">
</commandParameter>
<state
class="org.eclipse.jface.commands.RadioState"
id="radio">
</state>
</command>
</extension>
<extension
point="org.eclipse.ui.menus">
<menuContribution
allPopups="false"
locationURI="popup:commandframework.views.SampleView">
<menu
id="commandframework.samplemenu"
label="SampleMenu">
<command
commandId="commandframework.command1"
style="radio">
<parameter
name="org.eclipse.ui.commands.radioStateParameter1"
value="left">
</parameter>
</command>
FUDForum. Page generated in 0.01698 seconds
