Home » Eclipse Projects » XML Schema Definition (XSD) » some kind of restriction(restricing a group of elements)
some kind of restriction [message #724406] Mon, 12 September 2011 05:55 Go to next message
Drd  is currently offline Drd
I have this sequence of elements in the xml:
<CONFIGURATION type="choice">
<AUTOSAVE>DISABLED</AUTOSAVE>
<PLAUSIBILITY>DISABLED</PLAUSIBILITY>
<PARA_CONF_FCT>DISABLED</PARA_CONF_FCT>
<CHECKSUM>DISABLED</CHECKSUM>
<PROTECTION_2OF3>ENABLED</PROTECTION_2OF3>
<PROTECTION_HAMMING>DISABLED</PROTECTION_HAMMING>
<EM_GROUP>1</EM_GROUP>
<description>
<!-- you can choose only one of the elements from the configuration to ENABLE ( EM_GROUP is not affected by this) -->
<!-- example:if the element AUTOSAVE is DISABLED then he will appear like so: EM_DISABLE_AUTOSAVE -->
<!-- example:if the element AUTOSAVE is ENABLED then he will appear like so: EM_ENABLE_AUTOSAVE -->
<!-- example:if EM_GROUP has the value 1 then the code will appear EM_GROUP_1 -->
</description>
</CONFIGURATION>
basically I need in the xsd to respect that description:
ONLY ONE of the elements can have the value ENABLED
please help and thx in advance
Re: some kind of restriction [message #724535 is a reply to message #724406] Mon, 12 September 2011 10:52 Go to previous message
Ed Merks is currently offline Ed Merks
This forum/newsgroup is for helping to understand and use the
org.eclipse.xsd API, not as a general XML Schema help forum.
> <description>
> EM_GROUP_1 -->
> </description>
> </CONFIGURATION>
Previous Topic:NewXMLGenerator.createCMDocument() returns null
Next Topic:Exclude files/folders from validation programmatically
Current Time: Fri May 24 09:08:25 EDT 2013
Powered by FUDForum. Page generated in 0.02908 seconds
