| @Embeddable Inheritance [message #724410] |
Mon, 12 September 2011 06:04  |
Hannes Messages: 11 Registered: September 2011 |
Junior Member |
I have an @Embeddable class (let's call it EmbeddableParent). EmbeddableParent is subclassed by another class, also annotated with @Embeddable (let's call this class EmbeddableChild). EmbeddableParent also embeds a third class EmbeddableC. To clear things up, a piece of sample code:
@Embeddable
public class EmbeddableC implements Serializable {
private String stringA;
private String stringB;
@Embeddable
public class EmbeddableParent implements Serializable {
@Embedded
private EmbeddableC embedded;
@Embeddable
public class EmbeddableChild extends EmbeddableParent implements Serializable {
I now used the DescriptorCustomizer and InheritancePolicy to make inheritance for Embeddables work, as suggested by en.wikibooks.org/wiki/Java_Persistence/Embeddables#Inheritance (Apparently I cannot post links, unless I have posted more than 5 messages.).
The code I wrote looks like this:
@Customizer(EmbeddableParent.class)
@Embeddable
public class EmbeddableParent implements Serializable, DescriptorCustomizer {
@Embedded
public void customize(ClassDescriptor descriptor) throws Exception {
descriptor.getInheritancePolicy().setSingleTableStrategy();
DatabaseField indicatorField = new DatabaseField();
indicatorField.setName("QTYPE");
indicatorField.setLength(20);
indicatorField.setType(java.lang.String.class);
descriptor.getInheritancePolicy().setClassIndicatorField(indicatorField);
descriptor.getInheritancePolicy().useClassNameAsIndicator();
@Embeddable
@Customizer(EmbeddableChild.class)
public class EmbeddableChild extends EmbeddableParent implements Serializable, DescriptorCustomizer {
public void customize(ClassDescriptor descriptor) {
descriptor.getInheritancePolicy().setParentClass(EmbeddableParent.class);
Using this code, generation of tables from entities fails with a NullPointerException:
at org.eclipse.persistence.descriptors.InheritancePolicy.updateTables(InheritancePolicy.java:1847)
1847 Vector<DatabaseTable> parentTables = getParentDescriptor().getTables();
at org.eclipse.persistence.descriptors.InheritancePolicy.postInitialize(InheritancePolicy.java:1122)
1121 ClassDescriptor parent = getParentDescriptor();
1122 if (parent.hasPreDeleteMappings()) {
It seems, parentDescriptor is not set correctly. What am I doing wrong? Did I miss something? Or is it a bug? Any help is appreciated.
[Updated on: Tue, 13 September 2011 14:55] Report message to a moderator
| (no subject) [message #726320 is a reply to message #725756] |
Sat, 17 September 2011 05:38   |
Hannes Messages: 14 Registered: March 2011 |
Junior Member |
Thank you for looking into this.
Here is the full output of "Generate Tables from Entities", including the stack trace:
[EL Config]: The access type for the persistent class [class test.embeddable.EntityClass] is set to [FIELD].
[EL Config]: The access type for the persistent class [class test.embeddable.EmbeddableChild] is set to [FIELD].
[EL Config]: The alias name for the entity class [class test.embeddable.EntityClass] is being defaulted to: EntityClass.
[EL Config]: The table name for entity [class test.embeddable.EntityClass] is being defaulted to: ENTITYCLASS.
[EL Config]: The column name for element [id] is being defaulted to: ID.
[EL Info]: EclipseLink, version: Eclipse Persistence Services - 2.3.0.v20110604-r9504
[EL Fine]: Detected Vendor platform: org.eclipse.persistence.platform.database.JavaDBPlatform
[EL Config]: Connection(1309828059)--connecting(DatabaseLogin(
platform=>JavaDBPlatform
user name=> ""
datasource URL=> "jdbc:derby:/Users/hannesweisbach/TestDB;create=true"
[EL Config]: Connection(123234458)--Connected: jdbc:derby:/Users/hannesweisbach/TestDB
User: APP
Database: Apache Derby Version: 10.8.1.2 - (1095077)
Driver: Apache Derby Embedded JDBC Driver Version: 10.8.1.2 - (1095077)
[EL Config]: Connection(1027299898)--connecting(DatabaseLogin(
user name=> ""
[EL Config]: Connection(1594820133)--Connected: jdbc:derby:/Users/hannesweisbach/TestDB
User: APP
[EL Severe]: Local Exception Stack:
Exception [EclipseLink-0] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.IntegrityException
Descriptor Exceptions:
Runtime Exceptions:
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:535)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:476)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:435)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.postConnectDatasource(DatabaseSessionImpl.java:673)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.loginAndDetectDatasource(DatabaseSessionImpl.java:618)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:206)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:472)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getDatabaseSession(EntityManagerFactoryDelegate.java:188)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.createEntityManagerImpl(EntityManagerFactoryDelegate.java:277)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:290)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:268)
at org.eclipse.jpt.jpa.eclipselink.core.ddlgen.Main.perform(Main.java:86)
at org.eclipse.jpt.jpa.eclipselink.core.ddlgen.Main.execute(Main.java:77)
at org.eclipse.jpt.jpa.eclipselink.core.ddlgen.Main.main(Main.java:64)
Exception in thread "main" javax.persistence.PersistenceException: Exception [EclipseLink-0] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.IntegrityException
Runtime Exceptions:
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:501)
Caused by: Exception [EclipseLink-0] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.IntegrityException
Runtime Exceptions:
... 7 more
Runtime Exceptions:
at org.eclipse.persistence.descriptors.InheritancePolicy.preInitialize(InheritancePolicy.java:1155)
at org.eclipse.persistence.descriptors.ClassDescriptor.preInitialize(ClassDescriptor.java:3616)
at org.eclipse.persistence.mappings.AggregateObjectMapping.initialize(AggregateObjectMapping.java:1156)
at org.eclipse.persistence.descriptors.ClassDescriptor.initialize(ClassDescriptor.java:2803)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:512)
at org.eclipse.persistence.descriptors.ClassDescriptor.postInitialize(ClassDescriptor.java:3461)
at org.eclipse.persistence.mappings.AggregateObjectMapping.postInitialize(AggregateObjectMapping.java:1357)
at org.eclipse.persistence.descriptors.ClassDescriptor.postInitialize(ClassDescriptor.java:3430)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:526)
Runtime Exceptions:
Runtime Exceptions:
Actually, at this point I really am trying to get the minimal example running, I posted earlier. I have attached a tarball containing the sources for the minimal example and the persistence.xml (without database configuration).
begin 644 EmbeddableInheritance.tar.bz2
M0EIH.3%!629362]N<KT`!D7_F=RQ(`!08__?[Z?_X/__W_H$```0"```&%`$
M_G"UJTL:`%`!HIDTTFF@T:(]1B>D-/4/03U,F(8AB9/2:&F@.830&@-&C"-!
MB-,3)B:#"-`R`9,!)""IX4S5/TIZ-0/4T-,)HR&@!HT,0-``.830&@-&C"-!
MB-,3)B:#"-`R`9,!$I-`@(GIBF$T](R:390:9-,FF@:&@#-)D^Y?8OH#UY-1
MP)PGQWUELDD0F0!6O%Q<G%C9B"YUP5"J)B`:@B0""=@=].8["!91X&XXI$1[
M9#4F"H05`A,,BC1I/S60UPEH$L4LR3(8A&.;M.'5F^=X:AC^/J8,-R.S#KF4
M!,W^D;-*3^S,E#=YDH@->FQ%I"ESVWM?(TW6.W#JGER;\;S(IJ3TH:_;F.9)
M0Y!J)/+"-5I>/#<QM.IP5"_7+5)#/O63!J%BV`6AMK9=EPR\GN6]>W>0EK2!
M+QS.P"<@#B>D`40C*B5`)?886L$K:49!T$0[1P:CL$3O+Y%@O-Y_#H.?]+EQ
MQ77!;%Z:61="VT\4P=##`#-W`V.W'#1K+$I6#)-$PATITVK-:EL\L3#'7GI7
M=3.9*0<;L*@VUM"AC:!8N@MHMY)VK)*Q\Q9*8*:1)*D/7":"ODC[ASZ=D6T=
M=S=1"9@CC800B;V=;43F'NGC>@!!P71.%MA=)-E`!N>"`$;=R+F95/@QZV]_
M,XM%[&X<!$NF<9(<UK\\N@#CG+?R9;5-4.Z[K)$001'1F[-.3OCRY<!D-6F'
M9B,#$%95NBF&?+ZI;DUN[*`)1@/RGY+99JE29:E958;Z`^]!&MSV)I<O8'J@
M;U,[E4#).M?E#;[0Z_[._28I^/YKPG15?D7,W"/WO:&Y\MY1:+[5:KP;R]#K
M%"(AV`>0#%;NRQ=0+[+UZ<E`O#4&X/*'*N,D5`*U+0W:YX&5&03AYS=CK`@8
M2"3DSZ0Q,BZ=^[%V)LGF"CK]YNL2YA(AOK*)(N-UM:A9!M"#8$),RY#(<8H3
M\EWT.5N#:D#`N5-7N.OD72:.T&_`UE%SAD[C8J=TU#!A56Y>#8$2BZB&<"<8
M:@H<6E<?M6VPM#S#;U&R9C:!I6!R%NC]D/>;!J>D6>CF;PR<_HU;QI(Z5O`-
M:U5-18%J0>X)>&;<Z%V!:=N-U@;2!"`0<W#(1A`G>!#CG<(!Q!>N)EP\ZYBY
ML/H8A($1+&A8)X5S`%#P,>UC<WQ0@0Z;Y`H:UMO*LNHVW!@50O+C4[2N&"S,
ME#HWN<\04>$2]*&-#6M02P2T.0)93&`GQ!ZBS%+'>9FN$F#03282YCO$-*^/
M70`L*A#(NU86DA"1($4TT)%W+5:@;]H<`!<'`,YY<1!@MI@'7!P-A2!)`?3"
MFA?XQ`.[F7ETNP:F5!^'PXS#X^/$1RJZ,RZ%2"9VJUS+;%TV,`D&62HE[6H1
M=18A14MY_^#<'*/33>XL7!,1*+4D!@PX0NZDN.,-"=5X',9&PU?%<YU`:`,1
MB^G0&O=CE799P8+XKO75Q+)S;-(;:!]DWA+@.@/@>`Z53_Q=R13A0D"]N<KT
end
| Re: (no subject) [message #726865 is a reply to message #726316] |
Mon, 19 September 2011 14:28   |
James Sutherland Messages: 1844 Registered: July 2009 |
I believe that the issue is that the since the EmbeddableParent is never referenced by any Entity it is not processed, so their is no descriptor for it.
Does it work if you reference the parent instead of the child, or both?
You may be able to define a RelationalDescriptor for the parent in a SessionCustomizer.
This may have been resolved, so you may wish to try the latest build. Otherwise log a bug and vote for it. The ideal fix would be to just support inheritance with embeddables in EclipseLink's JPA annotation processing.
James : Wiki : Book : Blog
| Re: (no subject) [message #731257 is a reply to message #727280] |
Fri, 30 September 2011 08:05  |
Junior Member |
Using a SessionCustomizer, i set the parent and child descriptors, respectively. The NullpointerException is gone, but the generated table is empty:
[EL Fine]: Connection(1237941458)--CREATE TABLE ENTITYCLASS (ID BIGINT NOT NULL, PRIMARY KEY (ID))
The code for the SessionCustomizer is as follows:
public void customize(Session session) throws Exception {
ClassDescriptor parent = session
.getClassDescriptor(EmbeddableParent.class);
ClassDescriptor child = session
.getClassDescriptor(EmbeddableChild.class);
child.getInheritancePolicy().setParentDescriptor(parent);
parent.getInheritancePolicy().addChildDescriptor(child);
I suppose, the empty table has something to do with EmbeddableParent no being referenced, so I added another entity, which embeds an EmbeddableParent object:
@Entity
public class OtherEntity {
@Id
@GeneratedValue
private long id;
@Embedded
EmbeddableParent z;
Now, when generating tables, the following NullpointerException occurs:
[EL Config]: The access type for the persistent class [class test.embeddable.OtherEntity] is set to [FIELD].
[EL Config]: The access type for the persistent class [class test.embeddable.EmbeddableParent] is set to [FIELD].
[EL Config]: The access type for the persistent class [class test.embeddable.EmbeddableA] is set to [FIELD].
[EL Config]: The alias name for the entity class [class test.embeddable.OtherEntity] is being defaulted to: OtherEntity.
[EL Config]: The table name for entity [class test.embeddable.OtherEntity] is being defaulted to: OTHERENTITY.
[EL Config]: The column name for element [b] is being defaulted to: B.
[EL Config]: The column name for element [a] is being defaulted to: A.
[EL Config]: The column name for element [c] is being defaulted to: C.
[EL Config]: Connection(1846341136)--connecting(DatabaseLogin(
user name=> ""
[EL Config]: Connection(1292981053)--Connected: jdbc:derby:/Users/hannesweisbach/TestDB
User: APP
[EL Config]: Connection(745533778)--connecting(DatabaseLogin(
user name=> ""
[EL Config]: Connection(1359545169)--Connected: jdbc:derby:/Users/hannesweisbach/TestDB
User: APP
[EL Info]: file:/Users/hannesweisbach/Documents/uni/master/salespoint/implementation/kp-salespoint/Embeddable_test/bin/_Embeddable_test_url=jdbc:derby:/Users/hannesweisbach/TestDB;create=true login successful
[EL Severe]: java.lang.NullPointerException
at org.eclipse.persistence.internal.helper.DatabaseField.getTableName(DatabaseField.java:312)
at org.eclipse.persistence.tools.schemaframework.DefaultTableGenerator.initTableSchema(DefaultTableGenerator.java:303)
at org.eclipse.persistence.tools.schemaframework.DefaultTableGenerator.generateDefaultTableCreator(DefaultTableGenerator.java:175)
at org.eclipse.persistence.tools.schemaframework.SchemaManager.getDefaultTableCreator(SchemaManager.java:902)
at org.eclipse.persistence.tools.schemaframework.SchemaManager.replaceDefaultTables(SchemaManager.java:953)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.createOrReplaceDefaultTables(EntityManagerFactoryProvider.java:90)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.writeDDLToDatabase(EntityManagerFactoryProvider.java:365)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.generateDDL(EntityManagerSetupImpl.java:2787)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:477)
Exception in thread "main" javax.persistence.PersistenceException: java.lang.NullPointerException
Caused by: java.lang.NullPointerException
... 7 more
Debugging showed, that the NullpointerException occurs, when the table for OtherEntity is created. For a field in EmbeddableParent, namely "String c", a DatabasField object is generated which does not have a table set.
FUDForum. Page generated in 0.02195 seconds
