Home » Eclipse Projects » DSDP - Real-Time Software Components (RTSC) » access enums of a proxy
access enums of a proxy [message #723878] Fri, 09 September 2011 14:46
linkinsebas is currently offline linkinsebas
Hello everybody.
Is it possible to access the enumerations defined within an interface from a module that uses this interface as proxy?
For example, if I have
interface IModuleWithEnum{
    /* Enumeration */
    enum State{
        State_0 = 0x00,
        State_1 = 0x01,
        State_2 = 0x02,
        State_3 = 0x03
    /* Function definitions... */
    Void fxn1();
and
module ModuleWithEnum inherits IModuleWithEnum{
I can access the elements of the enumeration from ModuleA.c using ModuleA_State_0 without any problems.
But then I define another module:
module ModuleWithProxy {
    proxy PModuleWithEnum inherits IModuleWithEnum;
    /* functions... */
and then I try to access the enumeration from the functions defined in ModuleWithProxy.c using ModuleWithProxy_PModuleWithEnum_State_0. But when I try to build the package, file ModuleWithProxy.c does not compile saying that "identifier ModuleWithProxy_PModuleWithEnum_State_0 is undefined" (However, accesses to ModuleWithProxy_PModuleWithEnum_fxn1() are recognized).
Is what I want to do possible? if so, how is it done? or am I just missing something trivial?
Previous Topic:Optimizations for speed
Next Topic:release script
Current Time: Wed May 29 03:21:46 EDT 2013
Powered by FUDForum. Page generated in 0.01548 seconds
