Home » General (non-technical) » Proposals » Eclipse Web Interface/Tablet UI(I wanted to propose an Eclipse IDE for tablets or a web based IDE.)
Eclipse Web Interface/Tablet UI [message #723871] Fri, 09 September 2011 14:19 Go to next message
bobby is currently offline bobby
I would like to see Eclipse on Tablets, so that devs can code on the go. I understand that making an Eclipse IDE for each and every OS for Tablets out there can be an issue, so maybe a Web based IDE would be a good solution. Just a thought.
I for one would love to be able to use my tablets to code and work on. Migrate from my desktop/laptop.
Bobby
Re: Eclipse Web Interface/Tablet UI [message #723950 is a reply to message #723871] Fri, 09 September 2011 21:23 Go to previous messageGo to next message
Wayne Beaton is currently offline Wayne Beaton
Have you looked at Orion?
http://eclipse.org/orion/
Wayne
> Bobby
Re: Eclipse Web Interface/Tablet UI [message #723956 is a reply to message #723950] Fri, 09 September 2011 22:30 Go to previous messageGo to next message
I just registered for the beta and logged into Orion ... It did not work for the browser on my tablet ... I use an HP touchpad, it has a WebKit browser, full HTML5 support
thanks! Your suggestion was very much appreciated
I'm thinking a native app will have to done at some point in time for a tablet to be a viable development tool
Re: Eclipse Web Interface/Tablet UI [message #730627 is a reply to message #723871] Wed, 28 September 2011 13:50 Go to previous messageGo to next message
Werner Keil is currently offline Werner Keil
Bobby,
While it's mainly tool support for Android SDKs and specialized Eclipse
distros like MotoDEV, a look at Sequoyah might also be worth if you're
interested in Tablet UI both Web and Native.
Werner
Re: Eclipse Web Interface/Tablet UI [message #756403 is a reply to message #723950] Sat, 12 November 2011 13:33 Go to previous message
I suggested it for TMW (http://www.eclipse.org/tmw/) but there seems little
activity in that project these days,
thus, if Orion is more active, are there concrete use cases to make it work
on Tablet or Mobile systems?
If so, please check out OpenDDR, the only real Open Mobile Device
Repository: http://www.openddr.org
Happy to help Orion with that, too where it benefits User Experience on
different devices.
Werner
"Wayne Beaton" <wayne@eclipse.org> schrieb im Newsbeitrag
news:j4edgs$s7k$1@news.eclipse.org...
> Wayne
>> Thanks,
>> Bobby
Previous Topic:Aptana Full Screen Proposal
Next Topic:error with visual editor plug in
Current Time: Fri May 24 05:59:59 EDT 2013
Powered by FUDForum. Page generated in 0.01842 seconds
