Home » Modeling » Epsilon » [Epsilon] File modified outside the editor
[Epsilon] File modified outside the editor [message #723854] Fri, 09 September 2011 13:04 Go to next message
Horacio Hoyos is currently offline Horacio Hoyos
For some reason after working some time on any of the Epsilon editors (text) I start getting an error message after I save the file:
Upadate Conflict
The file "my file" has been changed on the file system. Do you want to override the changes made in the file system?
I would think the editor changes something in the file after I save it, so when i try to save it again there are "changes in the file system". I haven't been able to narrow down the cause of this behavior, but I think it has something to do with copy/paste inside the Epsilon editors.
Horacio Hoyos Rodriguez
EngD Student
University Of York
Re: [Epsilon] File modified outside the editor [message #724871 is a reply to message #723854] Tue, 13 September 2011 07:49 Go to previous message
Louis Rose is currently offline Louis Rose
Hi Horacio,
I'm afraid that I've not seen this error before. What version of Eclipse and Epsilon you're using (see [1] for help on finding this information) and what operating system?
If you do find a way of recreating the problem, do let us know so that we can investigate.
Louis.
[1] http://www.eclipse.org/gmt/epsilon/doc/articles/minimal-examples/
Previous Topic:Using Epsilon in Java
Next Topic:[EuGENia] Nodes with images
Current Time: Wed May 22 01:44:00 EDT 2013
Powered by FUDForum. Page generated in 0.01465 seconds
