| Unable to convert a date string to a Date object in BIRT [message #254740] |
Fri, 07 September 2007 11:23  |
Originally posted by: jason.estep.cgifederal.com
I have a situation where I need to convert a date in string format to a Date
object, so I can select the MAX (most recent) date time value.
I haven't had any success in converting strings to dates in BIRT. At present
I split the string into its component pieces as separate variables (month,
day, year, hours, minutes, seconds). I have tried reconstructing the string
in various configurations for use with new Date(Date.parse(newDateString))
but Date.parse(newDateString) always returns NaN. I also tried var myDate =
new Date(), and then myDate.setFullYear(year), myDate.setDay(day), etc. This
caused BIRT core exceptions to occur.
Is there a specific string format I have to use for Date.parse? Is there any
other way I can turn this string into a Date object, with the time included?
Jason C. Estep
| Re: Unable to convert a date string to a Date object in BIRT [message #254761 is a reply to message #254740] |
Fri, 07 September 2007 17:40   |
Alex Krücken Messages: 8 Registered: July 2009 |
Junior Member |
Jason,
try Java's SimpleDateFormat:
myString = '15.9.2007 22:30';
df = new Packages.java.text.SimpleDateFormat("dd.M.yyyy HH:mm");
myDate = df.parse(myString);
myTest = DateTimeSpan.addDate(myDate, 0, 0, 1)
You can see or download this example at:
http://e-prostor.com/birt/samples/StringToDate.rptdesign
Alex
Jason Estep pravi:
> Jason C. Estep
| Re: Unable to convert a date string to a Date object in BIRT [message #723547 is a reply to message #723076] |
Thu, 08 September 2011 14:52  |
Jason Weathersby Messages: 9167 Registered: July 2009 |
This is because your first and last rows are not formatted as MMM-yyyy.
Jason
On 9/7/2011 11:00 AM, kayanserdar wrote:
> Hello Jason, Sorry for getting back to you. This solution works great :)
> Your help is much appreciated.
> Just want to inform you that when I added below expression in a computed
> columns I get same error stated in my previous email, however when i
> added as a column binding works fine.
> importPackage(Packages.java.text);
> new Date(dataSetRow["strdate"])
> df = new Packages.java.text.SimpleDateFormat("MMM-yyyy");
> myDate = df.parse(dataSetRow["strdate"]);
Jason Weathersby
BIRT Exchange
FUDForum. Page generated in 0.02543 seconds
