Home » Eclipse Projects » Virgo » Hot deployer activated too early
Hot deployer activated too early [message #723412] Thu, 08 September 2011 09:47 Go to next message
Erdal Karaca is currently offline Erdal Karaca
When copying big war files into the pickup folder, the hot deployer is activated and fails as the war is still being copied.
Is there some setting to handle this?
Re: Hot deployer activated too early [message #723416 is a reply to message #723412] Thu, 08 September 2011 09:54 Go to previous messageGo to next message
Violeta Georgieva is currently offline Violeta Georgieva
unfortunately no - we have bug reported already - https://bugs.eclipse.org/bugs/show_bug.cgi?id=353490
as a workaround - put the war file in the pickup and then start Virgo
[Updated on: Thu, 08 September 2011 09:54]
Report message to a moderator
Re: Hot deployer activated too early [message #723420 is a reply to message #723416] Thu, 08 September 2011 10:07 Go to previous messageGo to next message
Jack Lynch is currently offline Jack Lynch
Would copying the file into a repository directory (not an actively scanned one like repository/usr, but for example repository/ext) and deploying one-line plan pulling in the WAR work for you?
<plan name="mybigwar.plan" version="1.0.0" scoped="false" atomic="true"
    xmlns="http://www.eclipse.org/virgo/schema/plan"
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xsi:schemaLocation="http://www.eclipse.org/virgo/schema/plan
                        http://www.eclipse.org/virgo/schema/plan/eclipse-virgo-plan.xsd">
    <artifact type="bundle" name="<Bundle-SymbolicName value from MANIFEST of your WAR>" version="[1.0.0, 2.0.0)"/>
</plan>
Re: Hot deployer activated too early [message #723448 is a reply to message #723412] Thu, 08 September 2011 11:16 Go to previous message
Hristo Iliev is currently offline Hristo Iliev
The plan approach should be ok, provided that this is WAB. For plain WAR files the pickup remains the only option.
Unfortunately scan interval is currently fixed at 1 second so a big WAR cannot be easily deployed this way.
[Updated on: Thu, 08 September 2011 11:30]
Previous Topic:birt.war does not run properly
Next Topic:Can I use multiple Host entries in tomcat-server.xml
Current Time: Sat May 18 09:26:17 EDT 2013
Powered by FUDForum. Page generated in 0.01639 seconds
