| [BPMN2] What determines the id type of Definitions? [message #718895] |
Thu, 25 August 2011 11:11  |
tsurdilo Messages: 41 Registered: February 2011 |
Member |
Hi all, I am generating BPMN2 using eclipse.bpmn2 API. Looking at the generated definitions element, for example:
<bpmn2:definitions xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" ... id="f667d0cc-fe19-49eb-90eb-2efe17812663" ..../>
the id attribute is not of type NCName, which is what it should be as per BPMN20 xsd.
Looking at the BPMN20.ecore in eclipse.bpmn2 model Definitions extends BaseElement and BaseElement defines attribute "id" of EType EString[java.lang.String].
When I change this type to NCName however, my generated BPMN2 picks up this change for all elements _except_ the definition element where the id is still of type EString.
Could someone please let me know where in the model I can specifically change the type of the id attribute of the definitions element??
I also tried changing the Diagram element in DI.ecore and set the id type to NCName, however that did not do anything either. Please let me know if there is some magic going on here or am I missing something obvious.
Thank you!!
[Updated on: Thu, 25 August 2011 11:13] Report message to a moderator
| Re: [BPMN2] What determines the id type of Definitions? [message #723380 is a reply to message #718895] |
Thu, 08 September 2011 08:41  |
Henning Heitkoetter Messages: 21 Registered: April 2010 |
Junior Member |
I'm sorry, but I cannot reproduce your problem. The generated IDs of definitions (and all other BPMN 2 elements) are, in my case, all valid NCNames due to the underscore.
They are generated during save by Bpmn2ResourceImpl, which calls EcoreUtil.generateUUID to create the IDs. This always creates an ID with underscore.
Do you do anything special when creating the resource or the BPMN model, so that Bpmn2ResourceImpl is not used?
Henning
FUDForum. Page generated in 0.01785 seconds
