Home » Eclipse Projects » BIRT » Get report parameters with genReport.sh or birt viewer
Get report parameters with genReport.sh or birt viewer [message #722623] Tue, 06 September 2011 07:07 Go to next message
psuliga.ca is currently offline psuliga.ca
It is not possible at the moment to extract report parameters using genReport.sh or birt viewer.
It would be convenient to have such an option - integration with non-java apps would be a lot easier. Right now the only way of getting parameters is as described here: www.eclipse.org/birt/phoenix/deploy/usingPHP.php#parameter_form (sorry I cannot post links). However it can only work for web apps and isn't pretty. Not that calling genReport.sh or making a birt viewer request for parameters would be perfect but it would be a lot more acceptable Wink
Also if such an option is to be provided it would be nice to have at least those three output formats: csv, json and xml.
Does anybody know if there is anybody working on this or if there exists similar request somewhere in bugzilla?
Re: Get report parameters with genReport.sh or birt viewer [message #722711 is a reply to message #722623] Tue, 06 September 2011 10:43 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
The report engine api does provide a task to retrieve all the parameter
information. Are you wanting an example of this in a .sh file?
Jason
On 9/6/2011 7:07 AM, psuliga.ca wrote:
> Hi
> for parameters would be perfect but it would be a lot more acceptable ;)
Jason Weathersby
BIRT Exchange
Re: Get report parameters with genReport.sh or birt viewer [message #722980 is a reply to message #722711] Wed, 07 September 2011 07:10 Go to previous message
Jason Weathersby wrote on Tue, 06 September 2011 10:43
Jason
If you are saying that it is possible to run ReportRunner class from shell in order to get parameter information for particular report then yes - It'll be great to see an example. But by looking at ReportRunner.java file I don't think it is possible.
EDIT:
Nor it is possible to make a request to birt viewer to get just the parameter info for a report AFAIK.
And this is what I am asking for (if anybody reported similar requests or is anyboda already working on this)
[Updated on: Wed, 07 September 2011 07:14]
Report message to a moderator
Previous Topic:OutOfMemory when rendering a crosstab report in WebViewer
Next Topic:image reference in 3.7 designer/viewer mode
Current Time: Mon May 20 17:51:34 EDT 2013
Powered by FUDForum. Page generated in 0.01920 seconds
