Home » Eclipse Projects » BIRT » Scrool bar in a table
Scrool bar in a table [message #722799] Tue, 06 September 2011 14:12 Go to next message
BrunoBorba Mising name is currently offline BrunoBorba Mising name
Hi guys,
I need to put a scrollbar in a table element, is this possible?
  • Attachment: iwish.PNG
    (Size: 10.90KB, Downloaded 43 times)
Re: Scrool bar in a table [message #722810 is a reply to message #722799] Tue, 06 September 2011 14:49 Go to previous message
Jason Weathersby is currently offline Jason Weathersby
You could probably do this using a text element. Look at the attached
example that uses a text element in a table footer. Note that the table
header and detail rows are hidden. An onCreate script on the table and
detail row is used to build a table to use in the text element in the
footer. The text element has an oncreate script to set its text based
on the value created in the table/rows.
Jason
On 9/6/2011 2:12 PM, BrunoBorba wrote:
> Hi guys,
> Thanks
Jason Weathersby
BIRT Exchange
Previous Topic:Why the html content of the same rpt from defferent engines are not same.
Next Topic:Multiple child in cascading param group
Current Time: Tue Jun 18 02:45:34 EDT 2013
Powered by FUDForum. Page generated in 0.01736 seconds
