| Installing artifacts from Eclipse projects into Virgo manually [message #721289] |
Thu, 01 September 2011 07:10  |
Alexey Romanov Messages: 263 Registered: May 2010 |
I have a working (with some problems) application with Virgo 2.1 and want to check if moving to Virgo 3.0 resolves these problems. I don't see any way to add a Virgo 3.0 server to Virgo IDE, so the next thing I wanted to try was to install the artifacts manually via Virgo Admin Console. However, this requires me to upload specific files.
I have 1) a Spring project (ru.focusmedia.odp.ssd.db) containing only .xml which configures the database drivers; 2) a par (PSHD) containing 4 other projects. From looking at the 2.1.1 server, there is a /stage subfolder which contains subfolders ru.focusmedia.odp.ssd.db.jar and PSHD.par. Presumably, copying it to Virgo 3.0 server isn't enough: Virgo IDE also has a way to set startup order. What else does need to be done? Is there a simpler/better way to try the application in Virgo 3.0?
FUDForum. Page generated in 0.01644 seconds
