Home » Eclipse Projects » Virgo » Can't create plan project as described in Programmer Guide
Can't create plan project as described in Programmer Guide [message #721678] Fri, 02 September 2011 10:23 Go to next message
Alexey Romanov is currently offline Alexey Romanov
According to the Programmer Guide (for both 2.1.1 and 3.0.0),
This is done by creating a new faceted project and then applying the OSGi Plan facet.
However, after doing it I get this error:
Nature org.eclipse.virgo.ide.facet.core.plannature is missing prerequisite nature org.springframework.ide.eclipse.core.springnature.
Adding the facet to a Spring project works.
Virgo IDE version is the latest snapshot.
Re: Can't create plan project as described in Programmer Guide [message #721729 is a reply to message #721678] Fri, 02 September 2011 13:02 Go to previous messageGo to next message
Chris Frost is currently offline Chris Frost
This is a bug, I'm guessing it got introduced during the donation, a lot of the Spring STS (including Spring IDE) code got changed to reduce the dependency. Eventually we hope to make the Virgo tooling completely independent of Spring IDE. It would be great if you could raise this as a bug on the Virgo project. https://bugs.eclipse.org/bugs/buglist.cgi?cmdtype=runnamed&namedcmd=GW%2FVirgo%20Bugs
Thanks, Chris.
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
Re: Can't create plan project as described in Programmer Guide [message #721858 is a reply to message #721729] Sat, 03 September 2011 03:51 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=356656
Re: Can't create plan project as described in Programmer Guide [message #722294 is a reply to message #721858] Mon, 05 September 2011 05:20 Go to previous messageGo to next message
Excellent, thank you.
Re: Can't create plan project as described in Programmer Guide [message #722324 is a reply to message #722294] Mon, 05 September 2011 07:37 Go to previous message
After creating a plan from a Spring project, I don't get a .plan file. I can add one manually, and it has a special icon in Package Explorer, but 1) plan editor is just XML editor; 2) it can't be added to the server in the "Add and Remove" dialog. Is this as intended?
EDIT: scratch 2, I could add it after an Eclipse restart.
[Updated on: Mon, 05 September 2011 09:28]
Report message to a moderator
Previous Topic:Installing artifacts from Eclipse projects into Virgo manually
Next Topic:Failure invoking bundle.loadClass(String clazz) in version M06 and higher
Current Time: Fri May 24 08:32:12 EDT 2013
Powered by FUDForum. Page generated in 0.01785 seconds
