| Exporting bundle project uses incorrect MANIFEST.MF [message #721601] |
Fri, 02 September 2011 05:04  |
Alexey Romanov Messages: 263 Registered: May 2010 |
When using "Export > EclipseRT > Bundle Project" (this is provided by Virgo, right?) I get this warning:
JAR export finished with warnings. See details for additional information.
ru.focusmedia.odp.ssd.db/src/META-INF/MANIFEST.MF was replaced by the generated MANIFEST.MF and is no longer in the JAR.
And the generated MANIFEST.MF is useless: the result actually isn't an OSGi bundle. Of course, I can get the correct result by "Export > Java > JAR file" and setting "Use existing manifest from workspace", but then I need to manually change version number in .jardesc. Is there a way to export Bundle Project correctly?
| Re: Exporting bundle project uses incorrect MANIFEST.MF [message #721726 is a reply to message #721601] |
Fri, 02 September 2011 12:59   |
Chris Frost Messages: 222 Registered: January 2010 Location: Southampton, England |
This sounds like a bug in the exporter. Are you using Bundlor, if so you might need to update some settings names, I can help you if this is the case. This will hopefully be automated in the future for people coming across from the existing tools. Please remember the new tools, as donated to Eclipse, have only done a single milestone release, lots of ruff edges.
Chris
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
FUDForum. Page generated in 0.02741 seconds
