Home » Eclipse Projects » DSDP - Real-Time Software Components (RTSC) » Optimizations for speed
Optimizations for speed [message #721501] Thu, 01 September 2011 19:05
linkinsebas is currently offline linkinsebas
The module primer emphasizes that the same speed can be reached by using RTSC modules' functions and old-fashioned #define macros. What do I have to do to to get this?
For example, I have a module's function
Float Math_abs(Float number)
    return (number>0?number:-number);
How do I make this as fast as the following macro?
#define mf_abs(x) (x>0?x:-x)
I have been building the package like this:
var Build = xdc.useModule('xdc.bld.BuildEnvironment');
var Pkg = xdc.useModule('xdc.bld.PackageContents');
for each (var targ in Build.targets) {
    Pkg.addLibrary("lib/" + Pkg.name, targ, {profile: "whole_program"}).addObjects(["Math.c"]);
and using a ccsv4-based client program that calls both functions like this:
y_abs_mf=mf_abs(x_abs);
y_abs_Math=Math_abs(x_abs);
According to ccsv4's clock, the first one takes 5 instruction cycles, but the second one takes 14. How can I make this better?
Also I am interested in the following situation. I need to have a module where some variables are set at configuration time depending on one other config, but used as constants outside the module during run time. I figured that these variables have to be configs too, since constants declared in a module cannot be modified even in a configuration script (can they?). The module primer (lesson 6) says that configs can effectively become literals (#define). How can I get to do this? For example, my test client code goes like this:
y_const=def_const;
y_const=Math_count;
where def_const is a constant defined using #define, and count is a config from module Math. According to ccsv4's clock, the first one only takes one instruction, but the second one takes 3 (if I define count as const instead of config, I can get the second line to take only 1 instruction cycle).
Thanks for your help.
Previous Topic:dash in package name
Next Topic:access enums of a proxy
Current Time: Wed May 29 03:22:08 EDT 2013
Powered by FUDForum. Page generated in 0.01957 seconds
