| [b3 0.2.0] "Registry Directory not available..." [message #721245] |
Thu, 01 September 2011 04:42  |
Originally posted by: Ralf Zozmann
just after updating from 0.1 to 0.2 i cannot longer build any
aggregation site from a given *.b3aggr file. I replaced the old
'aggreate' command by 'validationSet' and leave all other options
untouched. My headless command to start b3 is:
<eclipse.launch app="b3" failonerror="true">
<args>
<arg value="-data" />
<arg value="${basedir}/.tmpWS" />
<arg value="-application" />
<arg value="org.eclipse.b3.cli.headless" />
<arg value="validationSet" />
<arg value="--buildModel" />
<arg value="@{b3file}" />
<arg value="--action" />
<arg value="CLEAN_BUILD" />
<arg value="--buildRoot" />
<arg value="${basedir}/_b3mirror" />
</args>
</eclipse.launch>
I got the message:
Build failed! Exception was java.lang.IllegalStateException: Registry
Directory not available: <my
path>/_b3mirror/p2/org.eclipse.equinox.p2.engine/profileRegistry.
The directory .../_b3mirror is not existing, but created while executing
of command. The stacktrace is:
java.lang.IllegalStateException: Registry Directory not available: <my
org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.restore(SimpleProfileRegistry.java:419)
org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.getProfileMap(SimpleProfileRegistry.java:277)
org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.getProfiles(SimpleProfileRegistry.java:259)
at org.eclipse.b3.aggregator.engine.Builder.run(Builder.java:1613)
at org.eclipse.b3.aggregator.engine.Builder.run(Builder.java:1688)
at org.eclipse.b3.cli.AbstractCommand.run(AbstractCommand.java:133)
at org.eclipse.b3.cli.Headless.run(Headless.java:161)
at org.eclipse.b3.cli.Headless.start(Headless.java:197)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Any hints?
Ralf
| Re: [b3 0.2.0] "Registry Directory not available..." [message #721266 is a reply to message #721245] |
Thu, 01 September 2011 05:38   |
Ok, looking into the buglist i found
https://bugs.eclipse.org/bugs/show_bug.cgi?id=354321. Changing my option
CLEAN_BUILD into BUILD does it. Now i have another problem...
On 09/01/2011 10:42 AM, Ralf Zozmann wrote:
> <args>
> </args>
> </eclipse.launch>
> I got the message:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> Any hints?
> Regards
> Ralf
FUDForum. Page generated in 0.01508 seconds
