| Unable to switch to Design View [message #718174] |
Tue, 23 August 2011 09:47  |
Caleb Messages: 22 Registered: July 2009 |
Junior Member |
I'm using a freshly installed Eclipse 3.7 (64bit), with the latest WindowBuilder for SWT that I've just downloaded on Win7 64bit.
I created a new SWT Application Window, which seems to run fine and show the code view, but whenever I click on the "Design" tab, I get the following error:
Quote:Internal Error
WindowBuilder encountered unexpected internal error.
This could be caused by a WindowBuilder bug or by a misconfiguration issue, conflict, partial update, etc.
java.lang.IllegalArgumentException: Path must include project and resource name: /org.eclipse.swt
Stack trace:
Stack trace:
at org.eclipse.core.runtime.Assert.isLegal(Assert.java:63)
at org.eclipse.core.internal.resources.Workspace.newResource(Workspace.java:2163)
at org.eclipse.core.internal.resources.Container.getFolder(Container.java:222)
at org.eclipse.wb.internal.core.utils.reflect.ProjectClassLoader.addAbsoluteLocation(ProjectClassLoader.java:280)
at org.eclipse.wb.internal.core.utils.reflect.ProjectClassLoader.addRuntimeClassPathEntries(ProjectClassLoader.java:124)
at org.eclipse.wb.internal.core.utils.reflect.ProjectClassLoader.addFragment_runtimeClassPathEntries(ProjectClassLoader.java:168)
at org.eclipse.wb.internal.core.utils.reflect.ProjectClassLoader.addFragments(ProjectClassLoader.java:157)
at org.eclipse.wb.internal.core.utils.reflect.ProjectClassLoader.addRuntimeClassPathEntries(ProjectClassLoader.java:127)
at org.eclipse.wb.internal.core.utils.reflect.ProjectClassLoader.getClasspathUrls(ProjectClassLoader.java:73)
at org.eclipse.wb.internal.core.utils.reflect.ProjectClassLoader.create(ProjectClassLoader.java:64)
at org.eclipse.wb.internal.core.parser.AbstractParseFactory.createClassLoader_project(AbstractParseFactory.java:792)
at org.eclipse.wb.internal.core.parser.AbstractParseFactory.getClassLoader(AbstractParseFactory.java:747)
at org.eclipse.wb.internal.core.parser.AbstractParseFactory.initializeClassLoader(AbstractParseFactory.java:732)
at org.eclipse.wb.internal.rcp.parser.ParseFactory.getRootContext(ParseFactory.java:132)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.prepareParseContext(JavaInfoParser.java:1185)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:244)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.access$9(JavaInfoParser.java:240)
at org.eclipse.wb.internal.core.parser.JavaInfoParser$1.runObject(JavaInfoParser.java:153)
at org.eclipse.wb.internal.core.parser.JavaInfoParser$1.runObject(JavaInfoParser.java:1)
at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.runDesignTime(ExecutionUtils.java:153)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:151)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:513)
at org.eclipse.wb.internal.core.editor.DesignPage.access$9(DesignPage.java:501)
at org.eclipse.wb.internal.core.editor.DesignPage$8$1.run(DesignPage.java:434)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4683)
at org.eclipse.wb.internal.core.editor.DesignPage$8.run(DesignPage.java:431)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF_withProgress(DesignPage.java:450)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:400)
at org.eclipse.wb.internal.core.editor.UndoManager.refreshDesignerEditor(UndoManager.java:381)
at org.eclipse.wb.internal.core.editor.UndoManager.activate(UndoManager.java:90)
at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState_True(DesignPage.java:248)
at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState(DesignPage.java:226)
at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode.showPage(DefaultMultiMode.java:125)
at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode$1.widgetSelected(DefaultMultiMode.java:63)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:774)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:2745)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1432)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:257)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Full context stack trace:
| Re: Unable to switch to Design View [message #718578 is a reply to message #718390] |
Wed, 24 August 2011 13:37   |
Konstantin Scheglov Messages: 547 Registered: July 2009 |
It seems that you try to use project where source and output location are project itself, instead of "src" and "bin".
Actually I can not even force Eclipse to create such project.
I think that link which you provide is very old.
Now recommended way to create SWT/JFace project is creating plugin and importing SWT, JFace and other plugins, so allow PDE manage classpath for you.
Konstantin Scheglov,
Google, Inc.
| Re: Unable to switch to Design View [message #718870 is a reply to message #718595] |
Thu, 25 August 2011 10:29   |
User libraries is something in the middle between:
1. adding jars directly into project;
2. managing classpath using PDE.
Such libraries allow use make modifications only in one place, instead of changing classpath for each project.
But when you update your Eclipse you still will need to change library to include new SWT, JFace, etc.
In contrast with PDE you specify name of library and PDE will find and use it in your plugins folder.
Google, Inc.
FUDForum. Page generated in 0.04720 seconds
